Fatek Protected File
другие контроллеры
EmilianoFT
Re: Fatek Protected File
Post by EmilianoFT » Thu Jun 07, 2018 2:10 am
marea wrote:Hi Vlad2006gr
Can you help me unlock this file?
https://drive.google.com/file/d/1JdhP7j ... sp=sharing
Pwd: 19911112
marea
Post by marea » Mon Jun 11, 2018 5:55 am
thank you so much Vlad2006gr
elwan3
Post by elwan3 » Sun Jul 15, 2018 11:42 am
Hi Vlad2006gr
Can you help me getting password for this file?
http://www.mediafire.com/file/h4brb7h2k ... 1.pdw/file
vlad2006gr
Post by vlad2006gr » Sun Jul 15, 2018 5:56 pm
elwan3 wrote:Can you help me getting password for this file?
3233708
Good luck!
elwan3
Post by elwan3 » Sun Jul 15, 2018 9:40 pm
3233708
Good luck!
Thank you so much vlad2006gr
Brima
Post by Brima » Thu Sep 20, 2018 6:42 am
Hi Vlad2006gr,
There is a block password on this FATEK FB file.
https://www.dropbox.com/s/hbdgtn60vn65nsb/Copy.pdw?dl=0
Can you please help?
BEST REGARDS
azoth
Post by azoth » Sun Sep 23, 2018 6:36 am
Good afternoon!
Who can tell, the Fatek FBs controller, when trying to connect or look at its status, disconnects the connection with an error - Can not open the customer ID file (fatek (a) .cif). Tried to deceive him and throw the file with the name fatek.cif in the folder with WinProladder, then the error - The format of the customer ID file is incorrect.
День добрый!
Кто может подсказать, контроллер Fatek FBs, при попытке соединиться или посмотреть его состояние отключает соединение с ошибкой - Can't open the customer ID file ( fatek(a).cif). Пытался его обмануть и закинуть файл с названием fatek.cif в папку с WinProladder, тогда ошибка - The format of customer ID file is incorrect.
vlad2006gr
Post by vlad2006gr » Sun Sep 23, 2018 5:30 pm
Brima wrote:There is a block password on this FATEK FB file.
This is for new versions of the program. See PM.
vlad2006gr
Post by vlad2006gr » Sun Sep 23, 2018 6:46 pm
azoth wrote:Кто может подсказать, контроллер Fatek FBs
cif файл - это Customer identification code или Идентификационный код клиента. Этот ПЛК программировали на заводе или официальным представителем имеющим свой CIF. У FATEK SYSTEM SA например CIF -A20156543. Мало иметь сам файл, при попытку подключения к такому ПЛК, при наличии файла, у вас будет запрос пароля для авторизации под этим номером. Мне такие ПЛК не попадались, сказать как можно подключиться не знаю.
azoth
Post by azoth » Mon Sep 24, 2018 4:21 pm
To "vlad2006gr"
А известна структура файла fatek.cif?
Заранее спасибо!
vlad2006gr
Post by vlad2006gr » Wed Sep 26, 2018 6:41 am
Программа ищет при запуске файл fateka.cif. На одном из форумов был про это разговор. Как он выглядит, никто не знает. При наличии его вы должны пройти авторизацию. Решение так и не было найдено. Мне такая ситуация не попадалась. При сканировании сети на подключении, должна появиться картинка с данными контроллера. Что в ней написано?
Запуск программы без файла fateka.cif
С файлом fateka.cif
azoth
Post by azoth » Wed Sep 26, 2018 7:56 am
vlad2006gr спасибо!!!
Буду копать дальше!
Если что нарою,отпишусь!
azoth
Post by azoth » Thu Sep 27, 2018 5:09 am
To vlad2006gr
При попытках Get System Status of PLC в новых WpLad-ах, начиная с 250, так же пишет Can't open customer ID file.
Но в старых, начиная с 230, выдает полный статус, и там среди прочего видно что PLC ID - SET!
Это WpLad версия 2.30 сразу выдает
[img]http://5cm.ru/view/i7/ELeD.jpg[/img]
А WpLad версия 2.40 вначале просит
[img]http://5cm.ru/view/i7/kMzr.jpg[/img]
а потом
[img]http://5cm.ru/view/i7/FjiF.jpg[/img]
Как с этим бороться?
Может где есть подборки ROM-ов?
Не операционки, а образы!
vlad2006gr
Post by vlad2006gr » Thu Sep 27, 2018 12:04 pm
Почитайте про кустомер айди
http://ftp.fatek.pl/HMI/Instrukcja_obsl ... Manual.pdf
По самим ПЛК, вроде это можно использовать с версии FBs OS V4.50
azoth
Post by azoth » Thu Sep 27, 2018 2:04 pm
Самое интересное, что контроллер у которого установлен PLC ID, нельзя заново инициализировать без файлов fatek.cif или fateka.cif.
То есть очистить полностью контроллер и использовать для других целей - НЕЛЬЗЯ!
PLC ID - рвет коммуникацию WinProladder-а с контроллером если не находит нужный файл (п. 14) или если диск С не соответствует (п. 31 - 32)
14 19:11:46 WProlad.exe:976 OPEN C:\Program Files\Fatek\WinProladder 3.28\fateka.cif SUCCESS Options: Open Access: Read-Attributes
15 19:11:46 WProlad.exe:976 QUERY INFORMATION C:\Program Files\Fatek\WinProladder 3.28\fateka.cif SUCCESS Attributes: A
16 19:11:46 WProlad.exe:976 CLOSE C:\Program Files\Fatek\WinProladder 3.28\fateka.cif SUCCESS
17 19:11:46 WProlad.exe:976 OPEN C:\Program Files\Fatek\WinProladder 3.28\fateka.cif SUCCESS Options: Open Access: Read
18 19:11:46 MSMPENG.EXE:1416 QUERY INFORMATION C:\Program Files\Fatek\WinProladder 3.28\fateka.cif SUCCESS Length: 24261
19 19:11:46 MSMPENG.EXE:1416 READ C:\Program Files\Fatek\WinProladder 3.28\fateka.cif SUCCESS Offset: 0 Length: 24576
20 19:11:46 MSMPENG.EXE:1416 READ C: SUCCESS Offset: 5079040 Length: 32768
21 19:11:46 MSMPENG.EXE:1416 READ C: SUCCESS Offset: 21430272 Length: 32768
22 19:11:46 MSMPENG.EXE:1416 READ C: SUCCESS Offset: 21463040 Length: 32768
23 19:11:46 MSMPENG.EXE:1416 READ C: SUCCESS Offset: 38469632 Length: 32768
24 19:11:46 MSMPENG.EXE:1416 READ C: SUCCESS Offset: 38436864 Length: 32768
25 19:11:46 MSMPENG.EXE:1416 READ C: SUCCESS Offset: 57540608 Length: 32768
26 19:11:46 MSMPENG.EXE:1416 READ C: SUCCESS Offset: 57475072 Length: 32768
27 19:11:46 MSMPENG.EXE:1416 READ C: SUCCESS Offset: 57442304 Length: 32768
28 19:11:46 MSMPENG.EXE:1416 READ C: SUCCESS Offset: 70090752 Length: 32768
29 19:11:46 WProlad.exe:976 CLOSE C:\Program Files\Fatek\WinProladder 3.28\fateka.cif SUCCESS
30 19:11:46 WProlad.exe:976 OPEN C:\ SUCCESS Options: Open Directory Access: 00100001
31 19:11:46 WProlad.exe:976 QUERY INFORMATION C:\ SUCCESS FileNameInformation
32 19:11:46 WProlad.exe:976 QUERY INFORMATION C:\ SUCCESS FileFsVolumeInformation
33 19:11:46 WProlad.exe:976 QUERY INFORMATION C:\ SUCCESS FileFsAttributeInformation
34 19:11:46 WProlad.exe:976 CLOSE C:\ SUCCESS
35 19:11:46 WProlad.exe:976 OPEN C:\Program Files\Fatek\WinProladder 3.28\fateka.cif SUCCESS Options: Open Access: 0012019F
36 19:11:46 WProlad.exe:976 CREATE C:\Program Files\Fatek\WinProladder 3.28\ciftmp.fbk SUCCESS Options: OverwriteIf Access: 0012019F
37 19:11:46 WProlad.exe:976 QUERY INFORMATION C:\Program Files\Fatek\WinProladder 3.28\fateka.cif SUCCESS Length: 24261
38 19:11:46 WProlad.exe:976 READ C:\Program Files\Fatek\WinProladder 3.28\fateka.cif SUCCESS Offset: 0 Length: 1
39 19:11:46 WProlad.exe:976 READ C:\Program Files\Fatek\WinProladder 3.28\fateka.cif SUCCESS Offset: 1 Length: 1
40 19:11:46 WProlad.exe:976 READ C:\Program Files\Fatek\WinProladder 3.28\fateka.cif SUCCESS Offset: 2 Length: 1
41 19:11:46 WProlad.exe:976 READ C:\Program Files\Fatek\WinProladder 3.28\fateka.cif SUCCESS Offset: 3 Length: 1
42 19:11:46 WProlad.exe:976 READ C:\Program Files\Fatek\WinProladder 3.28\fateka.cif SUCCESS Offset: 4 Length: 1
43 19:11:46 WProlad.exe:976 READ C:\Program Files\Fatek\WinProladder 3.28\fateka.cif SUCCESS Offset: 5 Length: 1
44 19:11:46 WProlad.exe:976 READ C:\Program Files\Fatek\WinProladder 3.28\fateka.cif SUCCESS Offset: 6 Length: 1
45 19:11:46 WProlad.exe:976 READ C:\Program Files\Fatek\WinProladder 3.28\fateka.cif SUCCESS Offset: 7 Length: 1
46 19:11:46 WProlad.exe:976 CLOSE C:\Program Files\Fatek\WinProladder 3.28\fateka.cif SUCCESS
47 19:11:46 WProlad.exe:976 CLOSE C:\Program Files\Fatek\WinProladder 3.28\ciftmp.fbk SUCCESS
48 19:11:46 WProlad.exe:976 OPEN C:\Program Files\Fatek\WinProladder 3.28\ciftmp.fbk SUCCESS Options: Open Access: 00010080
49 19:11:46 WProlad.exe:976 QUERY INFORMATION C:\Program Files\Fatek\WinProladder 3.28\ciftmp.fbk INVALID PARAMETER FileAttributeTagInformation
50 19:11:46 WProlad.exe:976 DELETE C:\Program Files\Fatek\WinProladder 3.28\ciftmp.fbk SUCCESS
51 19:11:46 WProlad.exe:976 CLOSE C:\Program Files\Fatek\WinProladder 3.28\ciftmp.fbk SUCCESS
52 19:11:46 WProlad.exe:976 OPEN C:\Program Files\Fatek\WinProladder 3.28\ciftmp.fbk NOT FOUND Options: Open Access: Read-Attributes
53 19:11:46 WProlad.exe:976 OPEN C:\Program Files\Fatek\WinProladder 3.28\ciftmp.fbk NOT FOUND Options: Open Access: Read
Я пока не сдаюсь!)
Всем удачи!
dj1178
Re: [?]: How crack or unlock FATEK PLC password
Post by dj1178 » Wed Dec 26, 2018 2:25 am
eengr07 wrote:hi all.
i m having same problem with FBs-20MC..
when i attempt to get online the winproladder gives a message,enter password or ID...
I want to modify the existing code but i don't know the passward...please help me..
thanks advance..
I can crack it
woanxh
雷: [?] :如何破解或解锁命运PLC密码
Post by woanxh » Wed Dec 26, 2018 4:48 am
thanks advance..
I can crack it
Is smart200?
azoth
Post by azoth » Sat Jan 05, 2019 9:34 pm
to dj1178
Can you crack Fatek customer ID?
borodaus
Post by borodaus » Sat Feb 02, 2019 6:32 pm
Добрый день!
Перезалил проект с неисправного в исправный Fatek FBe-20MC. В RUN не выходит. Требует пароль ID. WinProladder V3.00 Build 12308 Cr не помогает, точнее, снимает только PASSWORD, а на Program ID ругается, снять не дает. (((
Будьте любезны, окажите помощь.
Проект здесь: https://dropmefiles.com/48h9e
И без пароля: https://dropmefiles.com/7YLNv
Заранее спасибо.
vlad2006gr
Post by vlad2006gr » Sun Feb 03, 2019 7:56 pm
borodaus wrote:Program ID ругается, снять не дает
Смотрим ПМ
borodaus
Post by borodaus » Sun Feb 03, 2019 8:26 pm
Спасибо! Завтра проверю, отпишусь.
Upd: Всё штатно заработало. Ещё раз спасибо!
azoth
Post by azoth » Wed Feb 06, 2019 12:33 pm
vlad2006gr можешь помочь?
[url]https://yadi.sk/d/9BaWjK7fcRCUJQ[/url]
[url]https://yadi.sk/d/XUJZ_7aPyehERA[/url]
Знаю что у этих программ пароль - 123456, ID дали - 111111, но он неверный.
[url]https://yadi.sk/d/zXBMoE0XjM5P9w[/url]
И у этой программы хотелось бы знать правильный ID и Pas!
В последней версии я сбросил оба и работаю, но в первых не могу сбросить ID!
Поможешь? Заранее спасибо!
vlad2006gr
Post by vlad2006gr » Wed Feb 06, 2019 7:12 pm
azoth wrote:Поможешь? Заранее спасибо!
См ПМ
azoth
Post by azoth » Thu Feb 07, 2019 9:48 am
И здесь СПАСИБО!)))
braptakis
Post by braptakis » Sun Feb 10, 2019 11:51 am
Hi Vlad2006gr,
I haven't the project saved in my PC. I'm trying to connect and ask me password, can i unlock the Fatek PLC?
ChesterSun
Post by ChesterSun » Mon Mar 11, 2019 7:49 am
Hello, all,
My PLC is wiped out due to a mistake. And I got the source code(.pdw file) with a password.
Could you share the crack software to me pls? Or could you leave your email address then I can send the .pdw file to you? I don't know how to upload an attachment.
Thanks in advance.
sunh2005@gmail.com
vlad2006gr
Post by vlad2006gr » Mon Mar 25, 2019 5:32 am
Put on any exchanger.
pop28
Post by pop28 » Tue Mar 26, 2019 8:18 pm
hello Vlad2006gr
please need help i have fatek plc v4.65 with plc password and id password can help me please
bladekel
Post by bladekel » Tue Apr 02, 2019 8:07 am
Hello Vlad2006gr,
Can you help me on unlocking these 2 file ?
https://drive.google.com/open?id=18CCo0 ... L6QCVd0-DG
vlad2006gr
Post by vlad2006gr » Tue Apr 02, 2019 12:24 pm
See PM.
SandiaLM
Post by SandiaLM » Thu Apr 18, 2019 12:57 am
Hey Vlad2006gr I have a programs that’s only got a password on the subroutine and I/O Configuration. Is there anything you can do with that?
vlad2006gr
Post by vlad2006gr » Thu Apr 18, 2019 5:56 am
Download the project, we'll see.
SandiaLM
Post by SandiaLM » Thu Apr 18, 2019 4:03 pm
There’s an error on the program that says present IO configuration is only available for MC model. The PLC is a model FBs-60MCJU-D24. When I try to save the project it doesn’t allow me because of the error. I would change the IO configuration but I can’t get in there without the password
vlad2006gr
Post by vlad2006gr » Fri Apr 19, 2019 9:53 am
First, give a screenshot of the program with system information.
PLC--> Quik Control-->Get System Status of PLC
hungbka
Post by hungbka » Fri May 24, 2019 1:06 pm
Dear Mr.vlad2006gr
I have two fatek PLC's programs that be protected by password sothat I can not see anything.
Pls help me read password of them. Thanks you
https://www.mediafire.com/file/9l65bad6 ... /fatek.rar
molehiya
Post by molehiya » Fri May 24, 2019 2:22 pm
Dear Mr.vlad2006gr
mdd1LINE1.pdw PASSWORD = ZHANGDIT
MDD1line2.pdw PASSWORD = ZHANGDIT
CCLIUULTRA
Post by CCLIUULTRA » Tue Jun 04, 2019 3:49 pm
ziconltai wrote:
Tue Dec 29, 2015 3:27 am
Pass ID :061181
https://www.dropbox.com/sm/share_link/C ... ssword.rar
Hello
The link to the file has expired!
Can you please post a new link?
Thank you very much for your help.
LittleCat
Post by LittleCat » Sat Jun 15, 2019 5:02 am
Dear Mr.vlad2006gr
I have a fatek PLC's programs that be protected by password please heip me to unlock, thanks so much!
https://drive.google.com/file/d/11MnRys ... sp=sharing
dj1178
Post by dj1178 » Tue Jun 18, 2019 8:25 am
hello Vlad2006gr
I can crack it
dj1178
Post by dj1178 » Tue Jun 18, 2019 8:26 am
Dear Mr.vlad2006gr
I can crack it but i cannot download your program
vlad2006gr
Post by vlad2006gr » Tue Jun 18, 2019 11:24 am
See PM
CCLIUULTRA
Post by CCLIUULTRA » Fri Jun 21, 2019 7:42 am
Dear Mr.vlad2006gr
password=798105
MOANEENOO
Post by MOANEENOO » Mon Jul 01, 2019 5:02 pm
PLEASW CAN I GET THIS FATEK PLC LADDER PASSWORD
https://drive.google.com/drive/my-drive
dekor
Post by dekor » Sat Jul 20, 2019 11:04 am
Hi Vlad2006gr,
please, can you tell me password for next files:
PLC
https://drive.google.com/open?id=1WenfJ ... lsoQcAqTD0
HMI
https://drive.google.com/open?id=1ws5e_ ... yX4sBrB0d-
Thanks in advance.
vlad2006gr
Post by vlad2006gr » Sun Jul 21, 2019 7:31 pm
Link?
See PM
huuthanh92
Post by huuthanh92 » Mon Jul 29, 2019 6:36 am
Dear Mr.vlad2006gr
I have a fatek PLC's sub programs that be protected by password please heip me to unlock, thanks so much!
https://www.mediafire.com/#myfiles
vlad2006gr
Post by vlad2006gr » Fri Aug 02, 2019 12:11 pm
try it yourself download this link-
Dear Mr.vlad2006gr
benyhof
Post by benyhof » Mon Aug 19, 2019 8:54 pm
Dear Mr.vlad2006gr
can you help me with pasw and ID?
https://uloz.to/file/3X92kuO7cvGN/edit-5t-pdw
vlad2006gr
Post by vlad2006gr » Wed Aug 21, 2019 6:08 pm
See PM
benyhof
Post by benyhof » Thu Aug 22, 2019 10:26 am
THX mistr Mr.vlad2006gr .... helped a lot ...
(clap) (clap) (clap) (clap) (clap) (clap) (clap)
