How can Kepware connect Siemens S7-1500
happy01234
Post by happy01234 » Tue Feb 23, 2016 11:40 am
I have used Kepware KEPServer v4.5 to connect to Siemens S7-300/400 for Opc.
but i can't find the Siemens S7-1500 option;
How can Kepware connect Siemens S7-1500? (oo)
hmohamed
Re: How can Kepware connect Siemens S7-1500
Post by hmohamed » Tue Feb 23, 2016 5:19 pm
search the web you will find a video on youtube website describing how to do this
happy01234
Post by happy01234 » Wed Feb 24, 2016 7:21 am
i cann't find the video,could you give me the URL
liquidevil
Post by liquidevil » Thu Apr 28, 2016 5:38 am
Hello!
I have found a solution and I will post it here if someone is interested.
Tested with KEPServer V4.500.465.0
1. Add "Siemens TCP/IP Ethernet" channel
2. Add a device and choose S7-300 as model
3. Open "Device Properties" > "S7 Comm. Parameters"
4. Choose Link Type "OP"
5. Here comes the problem; for the communication to work with S7-1x00 we have to set Rack = 0 and CPU Slot = 1. Unfortunately a limitation in KEPServer doesn't allow to input a number lower than 2 for CPU Slot. Just set Rack = 0 and CPU Slot = 2.
6. Close KEPServer and browse to your project file *.opf (usually under C:\Program Files (x86)\KEPServerEx\Projects)
7. Open the *.opf file with a HEX-editor. I use https://hexed.it/
8. Search for "00 02 57 4D 57 4D" and change the 02 to 01 and save the file
9. Open the edited *.opf-file in KEPServer. In "Device Properties" > "S7 Comm. Parameters" you should now see CPU Slot = 1
10. Now it works!
Remember that if you by mistake change CPU Slot you have to do all the steps from the beginning.
mailmat
Post by mailmat » Mon Jun 20, 2016 2:02 pm
(fback)
auto_keygen
Post by auto_keygen » Wed Jun 29, 2016 3:29 pm
happy01234 wrote:I have used Kepware KEPServer v4.5 to connect to Siemens S7-300/400 for Opc.
can you send me the download address link of kepware4.5 ,i searched the interner but only found kepware which is above version 5.0,thank you
gonline
Post by gonline » Thu Jul 21, 2016 9:00 am
You can setup an OPC Server towards S7-1500 using dataFEED OPC Server Siemens by Softing.
Configuration is very simple in 3 clicks.
ioannistsi
Post by ioannistsi » Wed Sep 21, 2016 4:41 am
Does this server connects with S7-1200 also?
hmohamed
Post by hmohamed » Mon Sep 26, 2016 7:23 am
ioannistsi wrote:Does this server connects with S7-1200 also?
yes it can
