HELP!!!URGENT vijeo citect work only with ebool and not inte
aacmpy
Post by aacmpy » Fri May 06, 2016 3:43 pm
Hello
I created a program in unity pro and HMI local on Vijeo Citect and communication between them realize by OFS OPC FACTORY .
before the program and hmi works very well but two day past
vijeo citect recoveres only ebool variables and not integer variables .
could you please help me in this problem
aacmpy
Re: HELP!!!URGENT vijeo citect work only with ebool and not
Post by aacmpy » Mon May 09, 2016 12:09 pm
up
Schtiel
Post by Schtiel » Mon May 09, 2016 5:19 pm
Post screenshots of your problem. Did you try your project on another PC with fresh installation of Citect?
aacmpy
Post by aacmpy » Tue May 10, 2016 12:59 pm
BEFORE
AFTER
apilife
Post by apilife » Mon May 16, 2016 5:04 pm
Do you use located variables? Or do you use the data dictionary with OFS?
And did you change (rebuild) the Unity Pro program?
NikitaF
Post by NikitaF » Mon May 30, 2016 6:19 am
If you rebuild unity program, you need to update XVM/STA file in OFS config.
