How can Kepware connect Siemens S7-1500
I have used Kepware KEPServer v4.5 to connect to Siemens S7-300/400 for Opc.
but i can't find the Siemens S7-1500 option;
How can Kepware connect Siemens S7-1500?
Re: How can Kepware connect Siemens S7-1500
search the web you will find a video on youtube website describing how to do this
i cann't find the video,could you give me the URL
Hello!
I have found a solution and I will post it here if someone is interested.
Tested with KEPServer V4.500.465.0
1. Add "Siemens TCP/IP Ethernet" channel
2. Add a device and choose S7-300 as model
3. Open "Device Properties" > "S7 Comm. Parameters"
4. Choose Link Type "OP"
5. Here comes the problem; for the communication to work with S7-1x00 we have to set Rack = 0 and CPU Slot = 1. Unfortunately a limitation in KEPServer doesn't allow to input a number lower than 2 for CPU Slot. Just set Rack = 0 and CPU Slot = 2.
6. Close KEPServer and browse to your project file *.opf (usually under C:\Program Files (x86)\KEPServerEx\Projects)
7. Open the *.opf file with a HEX-editor. I use https://hexed.it/
8. Search for "00 02 57 4D 57 4D" and change the 02 to 01 and save the file
9. Open the edited *.opf-file in KEPServer. In "Device Properties" > "S7 Comm. Parameters" you should now see CPU Slot = 1
10. Now it works!
Remember that if you by mistake change CPU Slot you have to do all the steps from the beginning.
10. Now it works!
can you send me the download address link of kepware4.5 ,i searched the interner but only found kepware which is above version 5.0,thank youhappy01234 wrote:I have used Kepware KEPServer v4.5 to connect to Siemens S7-300/400 for Opc.
You can setup an OPC Server towards S7-1500 using dataFEED OPC Server Siemens by Softing.
Configuration is very simple in 3 clicks.
Does this server connects with S7-1200 also?
yes it canioannistsi wrote:Does this server connects with S7-1200 also?
