Help on Unity Pro missing EFB
Help please I upload the program from existing Quantum PLC but after uploading when I try to rebuild the project it gives me error saying "Type not found in Types Library". There's a lot of EFB type that are not on the library.
Re: Help on Unity Pro missing EFB
This are the errors:
SHLR Type not found in Types Library,
RTSNDI16 Type not found in Types Library,
WORD4_TO_DT Type not found in Types Library,
TAKTG Type not found in Types Library,
RT_REG Type not found in Types Library,
TXSNDW8 Type not found in Types Library,
TXSNDW16 Type not found in Types Library,
B3IN1 Type not found in Types Library,
MOVE_INT Type not found in Types Library,
RT_SEND8 Type not found in Types Library,
TAKT Type not found in Types Library,
B3BEF Type not found in Types Library,
RTSNDG16 Type not found in Types Library,
EZKOM Type not found in Types Library,
TXSNDI16 Type not found in Types Library,
TXSNDG16 Type not found in Types Library,
B3IN2 Type not found in Types Library,
MOVE_BOOL Type not found in Types Library,
MOVE_REAL Type not found in Types Library
Process failed : 1 Error(s) , 0 Warning(s)
I'm using Unity Pro XL v8.0
I'm thinking the original programmer uses Unity EFB Toolkit..Is there a way on how to copy all this EFB into my library? Because I tried it can't.
Hello macroms,
this EFB's are from library B3000, which owner is company Cegelec (germany). This library was created by using Unity EFB Toolkit.
Yes Sir you're right the supplier for this PLC was Cegelec. But what's the best thing to do because I have to modify this PLC by adding NOE cards and additional network and it requires Rebuild all project.
Hello Macroms,
I hope you are not from SWCC? Nobody will provide B3000 libraries also not for fee. The only one right way to get the libraries is to ask Cegelec as supplier of plant.
Thanks a lot for the info.
