[LINK]:WinCC Flexible RT passwords viewer/analyzer
Utilites for Simatic HMI
mirotree123
[LINK]: WinCC Flexible RT unpasswords viewer program
Post by mirotree123 » Wed Jul 04, 2012 5:50 pm
tools for view password in WINCC flexible pdata.pwl
for PC Windows and Windows CE 5.0
MS Framework is required for PC Windows
FlexPWL-это программа для просмотра и разблокировки паролей OP панелей SIEMENS .
Как известно пароли на OP ,где проект был создан на WINCC flexible
хранятся в файле pdata.pwl или pdata.pwl1,так что главное найти эти файлы.Так же есть вариант
программы под windows ce 5.0(операционная система панелей).
Cсылка :
FlexPwl.rar
https://mega.co.nz/#!eNURWY6a!juyKAx5uX ... CRWLz3cdz0
http://f-bit.ru/369922
Select English
bilbo_321
Re: [LINK]: WinCC Flexible RT unpasswords viewer program
Post by bilbo_321 » Thu Jul 05, 2012 11:06 am
Good job! (clap)
paskalare
Post by paskalare » Fri Jul 06, 2012 8:54 am
very useful, specially in old projects where i forget almost everything (included the passwords) :D
mirotree123
Post by mirotree123 » Thu Feb 20, 2014 7:18 pm
Новая ссылка : http://f-bit.ru/369922
zafarictrl
Post by zafarictrl » Wed Feb 25, 2015 4:48 am
Dear all
thank you for your aid.
but how to find pass in wincc scada v7??
(gpost) (gpost)
wantutri
Post by wantutri » Tue Jun 02, 2015 3:55 am
Hi, may I know how is the FWL file generated? I can't seem to find the FWL in the project folder after rebuilding the project
Regards,
wantutri
omar zedan
Post by omar zedan » Sat Jun 27, 2015 6:34 pm
Dear all
how can I use this software??
mirco
Post by mirco » Wed Dec 14, 2016 11:02 pm
A tool for analyzing PWL / PWX files and extracting usernames and passwords:
https://mega.nz/#F!38BQ1bwR!3cxQJ0FdEUy5pPg9k5ZeKQ
xflash
Re: [LINK]:WinCC Flexible RT passwords viewer/analyzer
Post by xflash » Thu Dec 15, 2016 9:24 am
FlexPwl viewtopic.php?f=37&t=18007&p=53968&hilit=FlexPwl#p53968 is also doing the work.
mirco
Post by mirco » Mon Jan 16, 2017 12:47 pm
I've uploaded a new version of the tool, which also works with PWL files version 1.3 and 1.4 (TIA13 / 14).
The download link is the same (https://mega.nz/#F!38BQ1bwR!3cxQJ0FdEUy5pPg9k5ZeKQ).
xflash
Post by xflash » Tue Jan 17, 2017 3:03 am
mirco wrote:I've uploaded a new version of the tool, which also works with PWL files version 1.3 and 1.4 (TIA13 / 14).
This would be very very nice!
Post by CoMod » Tue Jan 17, 2017 6:30 am
please use date in file name
PWLAnalyzer_2017_01_16
PWLAnalyzer_2016_12_14
and add MD5 checksum file - for example see Sim_EKB_Install_2017_01_17 viewtopic.php?f=30&t=218
mirco
Post by mirco » Tue Jan 17, 2017 10:48 am
CoMod wrote:please use date in file name
Done:
PWLAnalyzer_2016_12_14.zip (MD5: 8382ed22dc0cce149ab5ef088a28aab5)
PWLAnalyzer_2017_01_16.zip (MD5: 38ab1cd7e84097839f35f1a57c358f39)
mel_w
Post by mel_w » Wed Jul 05, 2017 9:14 pm
works great on version 13 but doesn't show passwords on V14 SP1 only user names
Mel
mirco
Post by mirco » Tue Jul 25, 2017 5:50 am
From version 14 you can no longer see the password, because the password is no longer stored in the file.
Only the password hash is stored; using the "Test/reset password..." function from "Password" menu you can test if a password corresponds to the stored hash.
You can also reset the password (by forcing a new hash).
xflash
Post by xflash » Thu Jul 27, 2017 12:18 am
mirco wrote:From version 14 you can no longer see the password, because the password is no longer stored in the file.
Could you please get the hash to viewer? With hash, we maybe found a correct password. Which kind of hash does it use?
Thank you.
mirco
Post by mirco » Fri Jul 28, 2017 8:34 pm
xflash wrote: Could you please get the hash to viewer? With hash, we maybe found a correct password. Which kind of hash does it use?
You can view the hash from "Test/reset password..." dialog box (you can also copy-and-paste the hash as text).
The algorithm used is SHA256 (the password is also salted before hashing).
xflash
Post by xflash » Mon Jul 31, 2017 3:40 pm
Thank you. The algorithm they used seems to be too strong.
capow
Post by capow » Thu Apr 12, 2018 8:01 am
very good word
nikolay_i
Post by nikolay_i » Sat Apr 14, 2018 12:04 am
Добрый день. Можно свежую ссылку на скачивание? Очень нужно
