Hello
is there any news about releasing date for TIA PORTAL V13 SP1 and new 1500 firmware V1.7
thank you
[?]: TIA v13 SP1 and S7-1500 firmvare 1.7
Re: [?]: TIA v13 SP1 and S7-1500 firmvare 1.7
IT WILL BERELASED ON THE END OF JANUARY
OCAK 2015 SONU KARDESIM
Firmware is already for download and SP1 coming soon.
http://support.automation.siemens.com/W ... /106192301
Required software: TIA Portal with STEP 7 V13 SP1 Basic or STEP 7 V13 SP1 Professional
Note:
If after applying the firmware update according to the following instructions,
your CPU does not boot successfully,
or STEP 7 does not display V*.* for the firmware version,
return the CPU to Siemens for replacemen
https://support.automation.siemens.com/ ... reeLang=en
SIMATIC_STEP_7_Professional_SP1 http://support.automation.siemens.com/W ... /105825934
WinCC V13 Service Pack 1 http://support.automation.siemens.com/W ... /106567433
Startdrive V13 Service Pack 1 http://support.automation.siemens.com/W ... n/68034568
Safety V13 Service Pack 1 (to be released shortly)
