PDLFFALF
Post
by PDLFFALF » Sun Jan 25, 2015 3:40 am
javtell wrote:my site code is
F0B4 33E3 8436 2868 DC53 0CD4 B49A 57BF A6
can you generate the code for an engineering + runtime please ?
and if possible another code just for runtime
engineering + runtime:
[HKEY_CLASSES_ROOT\CLSID\{7E81D9FD-3656-4FA8-88EC-2437CE593EAE}\02]
"xe.eeragan MioudStn\\Bi1\\7. vioudStb Wet ofuSnd\\Iesil Famgrro\\PC:"="E5C4FDB20596C390328F5A8143BD6A07ACEC71685532FE1E4BC238E5186D7A49 3C"
runtime
"xe.eeragan MioudStn\\Bi1\\7. vioudStb Wet ofuSnd\\Iesil Famgrro\\PC:"="12A5962A0CFA1A6B6DAFA95255D019B876CA7DCD2D59C0CFD99DCC84C654E477 AC"
engineering
"xe.eeragan MioudStn\\Bi1\\7. vioudStb Wet ofuSnd\\Iesil Famgrro\\PC:"="A102AEFD2A1A0794C86AEDA2A286B354D1738C1B8E779E849B21710AA0235AC1 6C"
ciwa
Post
by ciwa » Sun Jan 25, 2015 6:47 am
my site code is 4FBF A385 41CB C289 2DA3 40C9 B7DC 2AC0 55
please generate engineering + runtime. Thanks
cail31
Post
by cail31 » Sun Jan 25, 2015 1:48 pm
My site code is
5885 86ED 5417 42FD 102B 0CFF 6BD9 13BD C9
can you generate the code for an engineering + runtime please with Advanced server plus?
PDLFFALF
Post
by PDLFFALF » Sun Jan 25, 2015 2:32 pm
ciwa wrote:my site code is 4FBF A385 41CB C289 2DA3 40C9 B7DC 2AC0 55
"xe.eeragan MioudStn\\Bi1\\7. vioudStb Wet ofuSnd\\Iesil Famgrro\\PC:"="6E48A7D884093EDB064F7FFCCCC2B8144210339911A36ECA1243919B1D0D6744 9F"
ciwa
Post
by ciwa » Sun Jan 25, 2015 3:16 pm
Thank you but when i check the license its engineering only, how about runtime license?
boss123
Post
by boss123 » Sun Jan 25, 2015 4:41 pm
Dears
It's not work, I imported the registry, but still there are no licence.
May be there anything missing?
Thanks a lot in advance
iyan
Post
by iyan » Sun Jan 25, 2015 6:47 pm
My site code is 1647 3A0C 2F97 AC2D A843 CFC2 9C8F 0E9A 22
would you please give me for engineering and runtime code. Thank you
PDLFFALF
Post
by PDLFFALF » Sun Jan 25, 2015 8:34 pm
iyan wrote:My site code is 1647 3A0C 2F97 AC2D A843 CFC2 9C8F 0E9A 22
"xe.eeragan MioudStn\\Bi1\\7. vioudStb Wet ofuSnd\\Iesil Famgrro\\PC:"="2F95C0B3ED058CA0E3D5077AB5D5339B87EC0863FCBB424B444140218E14D11F E8"
Moggasdog
Post
by Moggasdog » Sun Jan 25, 2015 9:19 pm
Site Code: 98BB 66C8 702C F88A 04CD 083F 6FCE F70B 46
Could you please send me a site key for development and runtime?
For those who have installed on 64 bit, you will need to edit the unireg.bat file to the path "C:\Program Files (x86)\InduSoft Web Studio v7.1\Bin\RunStudio.exe"
Thanks in advance!
PDLFFALF
Post
by PDLFFALF » Sun Jan 25, 2015 11:18 pm
Moggasdog wrote:Site Code: 98BB 66C8 702C F88A 04CD 083F 6FCE F70B 46
"xe.eeragan MioudStn\\Bi1\\7. vioudStb Wet ofuSnd\\Iesil Famgrro\\PC:"="FA82691EE4A7CABADAA16200068799A4AC7C592ADA31EAD66C03253331F304F4 DC"
Moggasdog
Post
by Moggasdog » Mon Jan 26, 2015 12:15 pm
Thanks for that but it is still going into demo mode.
I think i need the site key also??
Do I still have to enter the site key using the 'register' program?
The registry all updated with the .reg you sent but still no license?
Any help would be very much appreciated.
PDLFFALF
Post
by PDLFFALF » Mon Jan 26, 2015 2:30 pm
IWS 7.1 SP3:
http://pan.baidu.com/s/1eQtNpXw
1:Please download the file to get your PC site code:
http://pan.baidu.com/s/1i39WC8t
2:imported the reg-file with regedit.
3:launch Register from start menu located in Indusoft folder
4:switch the license to Softkey
5:run IWS.OK.
jandonian
Post
by jandonian » Mon Jan 26, 2015 3:51 pm
Dear Friend,
Can I have the site key (engineering + runtime) against the following site code:
68BE 173D CD7B E780 CA03 E242 8259 26D6 C0
Thanks in advance,
Jandonian
javtell
Post
by javtell » Mon Jan 26, 2015 4:18 pm
did it work for you ? i followed the steps but still running in demo mode.
i have windows xp 32 bits is there something missing?
i didnt downloaded the file to see my sitecode, i used the register to get thi site code could it be the problem?
javtell
Post
by javtell » Mon Jan 26, 2015 4:19 pm
ciwa wrote:Thank you but when i check the license its engineering only, how about runtime license?
how did you do to license the program i have followed the stps but still not working for me i have xp 32 bits
jandonian
Post
by jandonian » Mon Jan 26, 2015 5:10 pm
Dear Friend,
Thanks in advance,
Jandonian
boss123
Post
by boss123 » Mon Jan 26, 2015 8:17 pm
Dear Sirs,
My Site Code
10ED D5C3 1A30 5255 A14A 5E69 4E71 544A 42
Can you please generate site key the runtime & Engineering ?
Thanks a lot
Moggasdog
Post
by Moggasdog » Mon Jan 26, 2015 9:28 pm
now i have new site code:
95BD CFC5 B75F 737D B1BC 767C BD91 3E0C 12
I am really sorry, but could you send me a site key for engineering and runtime??
PDLFFALF
Post
by PDLFFALF » Tue Jan 27, 2015 5:42 am
[/quote]
"xe.eeragan MioudStn\\Bi1\\7. vioudStb Wet ofuSnd\\Iesil Famgrro\\PC:"="889D886E199DD558CC70AA8F9BC950100CF66C3AD5B7EE032EA488FECECEACFC 88"
Moggasdog
Post
by Moggasdog » Tue Jan 27, 2015 9:01 pm
Thanks for all of your help but it still only runs in demo mode. I have tried the exact steps that you suggest but it still wont work.
Maybe I should try it on a fresh install of Windows 7 and try again.
Moggasdog
Post
by Moggasdog » Tue Jan 27, 2015 9:07 pm
Yes - you need to use the program to get the site code - the zip contains another dll that runs with the IWS.exe installed of the installed version.
When I ran the downloaded bat file i got a different site code.
PDLFFALF
Post
by PDLFFALF » Wed Jan 28, 2015 12:19 am
mytom123
Post
by mytom123 » Wed Jan 28, 2015 8:22 am
My site code is E63D ED00 CB22 C062 520A EF9E 658D 98F2 5F
Could you give me engineer + runtime code . Thanks
PDLFFALF
Post
by PDLFFALF » Wed Jan 28, 2015 8:42 am
mytom123 wrote:Hi
"xe.eeragan MioudStn\\Bi1\\7. vioudStb Wet ofuSnd\\Iesil Famgrro\\PC:"="BEB6C087FADB0387AF9071536FA35B06189BE7EC1ED7E42EC88139FDF1F41F03 95"
mkoop
Post
by mkoop » Wed Jan 28, 2015 8:54 am
My Site Code: 8FDF 8446 9B9B 1C92 F55B B436 A751 8E8E AF
Could you give me engineer + runtime code please.
mytom123
Post
by mytom123 » Wed Jan 28, 2015 10:07 am
Do someone has a simple project and training manual?
Could you upload it?
Brgds
PDLFFALF
Post
by PDLFFALF » Wed Jan 28, 2015 10:29 am
mytom123 wrote:Hi
Brgds
ftp://ftp.icpdas.com/pub/cd/indusoft/
Moggasdog
Post
by Moggasdog » Wed Jan 28, 2015 4:32 pm
Thank you so much for your support.
I think what might be the problem is the Indusoft software with Keygen - the rar file seems to be corrupt and I am getting an CRC error. I cant find the Keygen.reg anywhere in the file I have downloaded so I think that there maybe some folders missing in the rar file that you have uploaded.
Would it be possible for you to upload the IndosftKeygen.rar file again?
Thank you very much.
el_pollo
Post
by el_pollo » Thu Jan 29, 2015 11:42 pm
please PDLFFALF need you help i can not get mi site key
actually i have IWS7.1 service pack 3 patch 4, please i need my site key
my site code is 1BEE 5E4F E1EE 30F9 BBEA 6DB3 C697 4135 1C
plesase
PDLFFALF
Post
by PDLFFALF » Fri Jan 30, 2015 1:05 am
el_pollo wrote:please PDLFFALF need you help i can not get mi site key
plesase
"xe.eeragan MioudStn\\Bi1\\7. vioudStb Wet ofuSnd\\Iesil Famgrro\\PC:"="13DA2B23B35C1467FBFCB6C9EAF6DF15EBD16F0068643C448A1F91EDF191107A D6"
riahc3
Post
by riahc3 » Fri Jan 30, 2015 9:44 am
Does this work for SP3 with Patch 4?
Also, could you please tell us how to generate the site key from a site code ourselves?
This way we ourselves can do it quickly and painlessly to several PC at the same time. Plus we dont have to bother you!
Moggasdog
Post
by Moggasdog » Fri Jan 30, 2015 11:57 am
PDLFFALF - could you upload the keygen again please?
I have tried 4 times to download the file but each time the rar is CRC corrupted and I thin the keygen that you used in the tutorial is not in the file.
el_pollo
Post
by el_pollo » Fri Jan 30, 2015 7:09 pm
sorry to bored you PDLFFALF, but i can't do it, i think i gave you wrong site code or something , could you please upload your keygen file?
or try with this site code again please 403F C0BE 0402 C1D0 0441 C30E 4736 6F8D FA
franklinleron
Post
by franklinleron » Sun Feb 01, 2015 8:16 pm
CAN YOU HELP ME WITH THE RUNTIME CODE PLEASE ?
MY SITECODE IS
E4D6 82B5 70F5 497D B168 13BF 4960 3C2E 77
riahc3
Post
by riahc3 » Mon Feb 02, 2015 8:50 am
Threads merged from what I see.....
PDLFFALF, The link to download key generator does not work . Only one video . No keygen . Please upload the keygen . Thank you
PDLFFALF, Các liên kết để tải về máy phát điện chính không hoạt động. Chỉ có một video. Không có keygen . Hãy tải lên các keygen . Cảm ơn bạn
manu1757
Post
by manu1757 » Tue Feb 03, 2015 5:43 pm
MY SITECODE IS
3771 F1B7 D627 7610 FBB6 577D 98B3 C867 C5
riahc3
Post
by riahc3 » Mon Feb 09, 2015 3:45 pm
No more replies?
abouelata
fabiovipa
Post
by fabiovipa » Sun Feb 15, 2015 12:26 pm
Ahmad_k or PDLFFALF give me Site key, please:
My site code is: AEC7 729F F743 2485 B010 2960 9B49 A89A 7E
Please give me Development + runtime site key.
Thank you so much!
PDLFFALF
Post
by PDLFFALF » Sun Feb 15, 2015 10:47 pm
el_pollo wrote:sorry to bored you PDLFFALF, but i can't do it, i think i gave you wrong site code or something , could you please upload your keygen file?
X32
"xe.eeragan MioudStn\\Bi1\\7. vioudStb Wet ofuSnd\\Iesil Famgrro\\PC:"="3C1383BAD528FD246BCDF2BF62B83D7F706F773087B4E31AEBA43C8E8F8EC699 30"
X64
[HKEY_CLASSES_ROOT\Wow6432Node\CLSID\{7E81D9FD-3656-4FA8-88EC-2437CE593EAE}\02]
"xe.eeragan MioudStn\\Bi1\\7. vioudStb Wet ofuSnd\\I6)x8 (esil Famgrro\\PC:"="3C1383BAD528FD246BCDF2BF62B83D7F706F773087B4E31AEBA43C8E8F8EC699 30"
PDLFFALF
Post
by PDLFFALF » Sun Feb 15, 2015 10:49 pm
franklinleron wrote:CAN YOU HELP ME WITH THE RUNTIME CODE PLEASE ?
MY SITECODE IS
X32
"xe.eeragan MioudStn\\Bi1\\7. vioudStb Wet ofuSnd\\Iesil Famgrro\\PC:"="92C437D7A0F20F43EC0C83FAC0F93D046DD19F458B6B420775F19FC0B144F246 BD"
X64
"xe.eeragan MioudStn\\Bi1\\7. vioudStb Wet ofuSnd\\I6)x8 (esil Famgrro\\PC:"="92C437D7A0F20F43EC0C83FAC0F93D046DD19F458B6B420775F19FC0B144F246 BD"
PDLFFALF
Post
by PDLFFALF » Sun Feb 15, 2015 10:53 pm
manu1757 wrote:CAN YOU HELP ME WITH THE RUNTIME CODE PLEASE ?
MY SITECODE IS
X32
"xe.eeragan MioudStn\\Bi1\\7. vioudStb Wet ofuSnd\\Iesil Famgrro\\PC:"="8474ED23E8B6D0FF70F96291B8A2607E06BA628C9C53A577DB04D83F1D0E8B2B 0F"
X64
"xe.eeragan MioudStn\\Bi1\\7. vioudStb Wet ofuSnd\\I6)x8 (esil Famgrro\\PC:"="8474ED23E8B6D0FF70F96291B8A2607E06BA628C9C53A577DB04D83F1D0E8B2B 0F"
PDLFFALF
Post
by PDLFFALF » Sun Feb 15, 2015 10:55 pm
abouelata wrote:My Site Code:
FAC3 ECB0 E09B 2EDB 67AC 9E3F 196C 8851 C8
can you create a site key please
Thank you so much.
X32
"xe.eeragan MioudStn\\Bi1\\7. vioudStb Wet ofuSnd\\Iesil Famgrro\\PC:"="4AEC687F614159DEF835ADBB66876BE7D074547A0182718E005D8DE8BFE6F35D 02"
X64
"xe.eeragan MioudStn\\Bi1\\7. vioudStb Wet ofuSnd\\I6)x8 (esil Famgrro\\PC:"="4AEC687F614159DEF835ADBB66876BE7D074547A0182718E005D8DE8BFE6F35D 02"
PDLFFALF
Post
by PDLFFALF » Sun Feb 15, 2015 10:57 pm
fabiovipa wrote:Ahmad_k or PDLFFALF give me Site key, please:
Thank you so much!
X32
"xe.eeragan MioudStn\\Bi1\\7. vioudStb Wet ofuSnd\\Iesil Famgrro\\PC:"="ACEB2DCB63E56D04127A328D3558A14284477CE8508A8E934082263F989ADF61 B4"
X64
"xe.eeragan MioudStn\\Bi1\\7. vioudStb Wet ofuSnd\\I6)x8 (esil Famgrro\\PC:"="ACEB2DCB63E56D04127A328D3558A14284477CE8508A8E934082263F989ADF61 B4"
riahc3
Post
by riahc3 » Tue Feb 17, 2015 8:29 am
PDLFFALF, why not give us the method on HOW you generate the keys? This way we do NOT bother you!
fabiovipa
Post
by fabiovipa » Tue Feb 17, 2015 7:56 pm
Hi PDLFFALF, please I do with this code generated you sent me, please help me, I watched the video,
more like I do not have the folder containing the KeyGen as in video'm a bit lost, please help me
riahc3
Post
by riahc3 » Wed Feb 18, 2015 9:22 am
fabiovipa wrote:Hi PDLFFALF, please I do with this code generated you sent me, please help me, I watched the video,
Exactly.
That is what is happening to everyone....I dont know why he doesnt want to give the keygen so we can use the software and not bother him.
maxx2828
Post
by maxx2828 » Wed Feb 18, 2015 3:24 pm
I need a help with IWS7.1 activation. My SiteCode 6FBF F1E3 5DCE 96F7 57C1 6D58 B213 07BF 64
abouelata
Post
by abouelata » Thu Feb 19, 2015 6:46 pm
eng Ahmad_k or eng PDLFFALF give me Site key, please:
My site code is: A74C 46D7 B7F9 8525 A7AB 1209 3500 807C A4
Thank you so much!
fabiovipa
Post
by fabiovipa » Thu Feb 19, 2015 7:16 pm
PDLFFALF wrote:
Hello PDLFFALF what I do with this code you sent me, please help me ...
Or someone from the forum could help me ... please
