Request: KEPServerEx V5.xxx
I need Kepware OPC Server V5.xxx with Patch/Keygen. Any link to that.
Thanks in advance.
Thanks in advance.
Re: Request: KEPServerEx V5.xxx
Keygen will not help you, version 5.xxx is protected by hardware key
Can Dongle Dump, simulator etc, help?
if you have sentinel dongle, maybe. In reteam.org i learn to dump for backup purposes.
Could someone help with crack/keygen for Kepware OPC 5.xx, I need it for S7-1200 testing(2h limit is a problem).
You Can Download NI OPC Server V2013.
It is KepServer V 5.12 OEM Version For NI.
DownloadLink:
http://download.ni.com/support/softlib/ ... ERVERS.exe
http://ftp.ni.com/support/softlib/ni_op ... ERVERS.exe
NI OPC Server V2013 Keygen Name is " NI License Activator 1.2 "
it Can Activator All V2013 version NI Software. but Only NI OPC Server V2013.
DownloadLink:
Question?
The NI OPC Server Can't use to other OPC Client.only NI Labeview.
The NI OPC Server CAN use to other OPC Client.
It Can be Used All OPC Client Software。
don't only for NI Labeview.
The NI OPC Server Have'd KEPServer PC Server most Function。
Friends Qiaopeng1231, Hello!
I just used Movicon 11.4 and RSVIEW32 tested, still can not connect to the NI OPC Server.keygen NI License Activator 1.2.
There was an error when connecting to NI OPC Servers: CocreateInstance such unauthorized use.
Therefore, you can't use third party OPC Client to connect NI OPC Server
NI said on the company website can be applied, such as NI LabView.
You can connect to NI OPC tutorials?
How to use NI OPC link to 3thrd OPCClient?
Can you help me? Thank you!
In addition, NI OPC Servers can only be connected to by the following clients: OPC Client I/O Server (requires LabVIEW DSC Module)
DataSockets
NI Lookout
NI OPC Quick Client
DataSockets
NI Lookout
NI OPC Quick Client
This solution only can link with labview software.Qiaopeng1231 wrote:You Can Download NI OPC Server V2013.
DownloadLink:
I try to connect visual basic and fluidsim and this was what happened:
last crack version is kep 4.5,NI opc server not support some kep plugins
darko_jd
Did you try to connect to NI OPC by dcom or by opc ua?
I can trade my V5 dongle image for Siemens kepware for another V5 dongle/license.
My v5 only works for an older V5.xxx since licenses are for specific date support
Edit: dongle image is working fully (multikey) on my Win7 x64:
stupid photo sharing
It only works until this version: (support subscription)
pic upload
pic upload
Last edited by monty_burns_007 on Tue May 12, 2015 6:29 pm, edited 1 time in total.
Which dongle type is there? You can send dongle dump in PM, will check if it's emulatable / changeable...monty_burns_007 wrote:I can trade my V5 dongle image for Siemens kepware for another V5 dongle/license.
Have patch for 1 year:
http://e10000.cn/a/a.asp?B=308&ID=2524456
anyone have account, please download and upload again in this topic.
Thanks!
Thanks!
Gruu...I have tried download and install the link that Link have uploaded.
Sorry, this is the monkey of forum member:
Game cat...
Game cat...
What did you try to say with this post?TuyenNL wrote:Gruu...I have tried download and install the link that Link have uploaded.
Game cat...
This patch do not work
HI people. I need KEPServerEx V4.5 with Patch/Keygen.
Please, it is very necessary ...
Any link to download KEPServerEx V4.5
Привет, народ. Мне нужно KEPServerEX V4.5 с Patch / Keygen.
Пожалуйста, очень нужно ...
Любая ссылка на скачивание KEPServerEX V4.5
Which operating system do you use?TuyenNL wrote:This patch do not work
I believe that's because KEPServerEXV5 service (executable file server_runtime.exe) on your PC uses usp10.dll from Windows/system32 folder and not from the place where you copied it. That could be checked by ProcessЕxplorer, for instance.
Probably usp10.dll is marked as 'known dll' at HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\KnownDLLs in registry
viewtopic.php?p=70660#p70660Pvalp wrote:Any link to download KEPServerEx V4.5
Re:
How to use it on windows 7 x64? Do you have an idea?Schtiel wrote:Which operating system do you use?TuyenNL wrote:This patch do not work
Re: Re:
You can reboot in safe mode, make backup of usp10.dll in C:\Windows\system32\ (or may be C:\Windows\syswow64\ ?), replace it with the version from archive.TuyenNL wrote:How to use it on windows 7 x64? Do you have an idea?
Reboot in normal mode and check.
Not tested - try on your own risk
Re: Re:
Have you checked on windows XP and Windows 2003? I think if it working fine, we'll have a solution for windows x64Schtiel wrote:You can reboot in safe mode, make backup of usp10.dll in C:\Windows\system32\ (or may be C:\Windows\syswow64\ ?), replace it with the version from archive.TuyenNL wrote:How to use it on windows 7 x64? Do you have an idea?
this patch not work on windows 2003.
and i found a patched for 5.17 three days trial:
patched files:
https://www.sendspace.com/file/gh7zyo
patched files:
tomsen wrote:this patch not work on windows 2003.
patched files:
Who can change into unlimited use?
Dear All
How can I download Kepware V5?
