[?]: adding EM 277 PROFIBUS DP module to S7-200
contech-eg
Post by contech-eg » Tue Feb 11, 2014 2:40 pm
I have a s7-200 PLC with a password protection for uploading. both communication ports of this PLC is used for communication with drives and HMI.
Can i add EM 277 PROFIBUS DP module for this PLC (s7-200)without chaning the program ??
thanks in advance
Homeroid_BL
Re: [?]: adding EM 277 PROFIBUS DP module to S7-200
Post by Homeroid_BL » Wed Feb 12, 2014 8:09 am
Basicaly, yes.
You can externaly (via DP master) set SMB200 to MSB249 to macth your needs.
But it is very hard to 'guess' data area where are variables you want to read/write, when you got a locked program.
And, if those variables are not in compast blocks (lenght of 64byte for I and Q), you are in big trouble.
contech-eg
Post by contech-eg » Wed Feb 12, 2014 11:07 am
can i use it as a PPI slave ?
Homeroid_BL
Post by Homeroid_BL » Wed Feb 12, 2014 11:59 pm
No, just for Profibus slave. There are no system commands to apply PPI protocol through port on expansion module.
