[?] 800xA DataDirect: Need Linkinx64's help
tuangp
Post by tuangp » Sat Feb 02, 2013 11:20 am
Hi Linkinx64,
Could you help me step by step How to create Report with DataDirect?
Many Thanks
Linkinx64
Re: [?] 800xA DataDirect: Need Linkinx64's help
Post by Linkinx64 » Mon Feb 04, 2013 8:40 am
Please specify the problem more details (with attached screenshots).
About those step-by-step you sent in PM:
1. Time difference occured because report creation time is different from the current system time. And the DataDirect templates are not provide autoupdate value by default. As well as the time stamp.
2. Sequence of generating report using Scheduling structure is right. I don't understand what's a problem can be...
tuangp
Post by tuangp » Mon Feb 04, 2013 11:21 am
Could you build a example to demonstration "How to create Shift-report automatically"?
tuangp
Post by tuangp » Sat May 18, 2013 4:10 am
Hi Linkinx64,
I need your help for "How to create automatically report when alarms&events occurs by DataDirect tool?".
Could you explain the concept of alarms&events report?
Many thank,
Tuan.
tuangp
Post by tuangp » Tue Jul 30, 2013 9:32 am
Hi Linkinx64,
I'm using DataDirect to create Shift Report. Some days ago, my report format as pic. below. The time sort oldest -> newest. (that's OK)
But today, my report automatic change sort time newest -> oldest. I don't what is changed. Time and date is wrong (2015???)
How to reconfig time sort oldest -> newest? (wow)
Linkinx64
Post by Linkinx64 » Tue Jul 30, 2013 12:55 pm
Upload your report template - I'll try to simulate time fault in my system.
tuangp
Post by tuangp » Tue Jul 30, 2013 6:07 pm
Linkinx64 wrote:Upload your report template - I'll try to simulate time fault in my system.
Check PM please.
Linkinx64
Post by Linkinx64 » Wed Jul 31, 2013 9:14 am
Check carefully expressions for the ABBGETOPCHDA(...) function. It could be due to incorrect function arguments (e.g. start time and end time are conversed or not correct data type specified or something similar).
Unfortunately on the 2nd picture I do not see full expression for the ABBGETOPCHDA and which values it take.
tuangp
Post by tuangp » Wed Jul 31, 2013 9:53 am
1.
Check data in Log Configuration. It's look OK. Time&Date is correct.
2.
Use DataDirect
3.
Excell. Wrong time, wrong year... (some time is 2015)
Linkinx64
Post by Linkinx64 » Wed Aug 07, 2013 10:37 am
Hi, Tuan
I am here but at the moment I still not found what can cause rearranging new->old issue.
I had tried to change time / disconnect from OPC server on my local system but it was not lead to rearranging date and shift it 2 years forward...
tuangp
Post by tuangp » Wed Aug 07, 2013 10:50 am
:lol:
I'm not lucky. I know my system is crazy.
Many thanks for your help. (pgood)
tuangp
Post by tuangp » Tue Oct 01, 2013 6:08 am
Hi Linkinx64,
Now my DataDirect report is wrong time & date again (ev)
Is this a bug of DataDirect?
I've used DataDirect ver5.1.5111.1110 in SV5.1 RevA FP1. Could I upgrade only DataDirect to ver 5.1.5812.0612 (in SV5.1.1 FP4) to fix my problem?
Linkinx64
Post by Linkinx64 » Tue Oct 01, 2013 10:33 am
tuangp wrote:I've used DataDirect ver5.1.5111.1110 in SV5.1 RevA FP1. Could I upgrade only DataDirect to ver 5.1.5812.0612 (in SV5.1.1 FP4) to fix my problem?
Partial update in 800xA is not supported - it can lead to unstable system behavior, failure, other unwanted consequences.
Exception: temporary correstions (TC) issuing by 800xA dev. team.
Therefore, there are 3 ways you need try now:
1. Check report template and OPC data consistency for the internal errors leading to the wrong date/time presentation.
2. (only if the 1st way is successfully commited) Request temporary corrections (TC) for DataDirect ver5.1.5111.1110 from ABB support center.
3. (if ABB support center was not able to identify problem) Update WHOLE system to v5.1.1.1 (FP4).
