[LINK]: EPLAN ELECTRIC P8 & PRO PANEL & FLUID & PPE v2.2
Тools, Elcad, Eplan, ...
kra101
Re: [LINK]: EPLAN ELECTRIC P8 & PRO PANEL & FLUID & PPE v2.2
Post by kra101 » Wed Jan 16, 2013 11:07 am
Hi Sadefa,
The same crack will work for Eplan P8 2.2 and Pro Panel as well?
Thanks in advance,
kra.
trak_inas
Re: [LINK]: EPLAN ELECTRIC P8 & PRO PANEL & FLUID v2.2
Post by trak_inas » Thu Jan 17, 2013 12:14 am
eplanner wrote:Hi, I had same problems like some of you.
Tried with that multikey from above link (v0.18.2.4):
- x64 version did NOT work on win7 x64 (error in device manager an/or license manager)
- x32 version did NOT work on win7 x86 (devcon error)
But it DOES work with an older Multikey (v0.18.1.0). Tested for x86 and x64. on win7 x64 SP1 and Win7 x86 SP1. (All in VMWare)
Just do it like titus95 said. Begin with a normal installation of eplan. uac off.
Hello
Can you please upload the files needed, because i already try with multikey (v0.18.1.0) and i have the hardlock in the device manager, but eplan says it isn't an correct dongle available
Bonavox
Post by Bonavox » Sun Jan 20, 2013 8:52 pm
trak_inas wrote:...i already try with multikey (v0.18.1.0) and i have the hardlock in the device manager, but eplan says it isn't an correct dongle available
Well, the same. "EPLAN Electric P8 2.2 is not included in the packet"
odairrocha-jr
Post by odairrocha-jr » Fri Jan 25, 2013 3:45 pm
Here is working perfectly in XP, just appears that error about hardware configuration, but works, I follow the steps that Risky73 had wrote.
Thanks guys!
kra101
Post by kra101 » Mon Jan 28, 2013 3:15 pm
Hi odairrocha-jr
Pro panel also working with the same crack?
trak_inas
Post by trak_inas » Mon Jan 28, 2013 6:29 pm
Hi, which operating system are you using?
32 or 64 bits?
kra101
Post by kra101 » Wed Jan 30, 2013 2:09 pm
Hi trak_inas,
Thanks for the reply
I have Windows XP Professional.
Josivan
Post by Josivan » Thu Jan 31, 2013 1:47 am
Can not run my EPLAN with the methods presented here, have some other way to generate the Dongle for Eplan 2.2
Windows 7 - 32bit (oo) (oo) :wink:
Josivan
Post by Josivan » Thu Jan 31, 2013 4:39 am
Hello all.
I managed to run Eplan 2.2 on Windows 8 32bits, however using the method of crack (2.2 CRACK EPLAN 10/23/2012) did not work, then opening the file setup.bat, I realized that it only copied the files to specified folders .
I describe here the steps I have done and it worked on Windows 7 32 bit and Windows 8 32 bit:
1 - Install Eplan Electric P8 2.2, follow the step usually gotten the istalação NOT RUN.
2 - Copy the file hardlock.sys to the directory C: \ Windows \ System32 \ Drivers
3 - Copy the file MYLOCK.FST to the directory C: \ Windows \ System32 \ Drivers
4 - Copy the SN-U10066.EGF to the directory C: \ Users \ Public \ EPLAN \ Common
5 - Restart the PC and start the EPLAN Electric P8 is ready to use.
I hope everyone Funcine con.
I'm leaving a sample image.
van8x10
Post by van8x10 » Thu Jan 31, 2013 10:15 am
At long last, I've installed successfully Eplan Electric P8 v2.2 for my laptop (Win7x64 build 7601 Enterprise) with v2.1 Sp1, both of them seem to be running ok.
My procedure as below:
I. Before Installing:
1. Download and unrar the Crack pack supplied by brepo (clap) (link http://speedy.sh/cHNxJ/eplan2.2x64.rar)
2. Rename the old file SN-U10066.EGF in C:\User\Public\EPLAN\Common with another extension name (SN-U10066.EGO for example), then copy the new file SN-U10066.EGF to this folder.
3. Turn off internet connection and antivirus software
4. Windows is still in Test Mode.
II. Installing:
1. Run Setup.exe as administrator
2. :!: In the Eplan Setup Manager>Master Data and Languages, uncheck "Installing the dongle driver" (important!)
3. Finish Installing.
III. Cracking:
1. Run file SN-U10066.reg to add data to the registry
2. Copy and overwrite all files in folder Multikey64 to C:\Windows\System32\Drivers
3. In this folder, Run file intall.cmd as administartor
4. Run the program dseo13b.exe as administrator; Add a digital signature for the driver Multikey. To do this, select "Sign a System File" and enter the filename including the full path "C:\Windows\System32\Drivers\multikey.sys",
5. Reboot the computer;
IV> RUN EPLAN:
- Do not disable Test Mode
- run eplan prof+
- Enjoy!
- Remember to turn on the antivirus software and internet connection :wink:
ghosttang
Post by ghosttang » Fri Feb 01, 2013 7:35 am
Oh hey,this's a great job!I can't viste hotfiles website in my country,if somebody upload on rapidshare ,that's very kindful! (clap)
maintenance
Post by maintenance » Sun Feb 03, 2013 4:26 am
alrealy i download it,but i can't crack.i try crack follow mr.Sadefa but not ok.please help me how to crack it.many thanks
odairrocha-jr
Post by odairrocha-jr » Wed Feb 06, 2013 11:57 am
kra101 wrote:Hi odairrocha-jr
Hello, I'm just using Eplan Eletric P8 and i haven't tryed with another version of Eplan! (sorry)
And this version is very instable, I have had many problens, this crack crashes many times! :evil:
odairrocha-jr
Post by odairrocha-jr » Wed Feb 06, 2013 12:08 pm
E ai Josivan, por um acaso você tentou seguir esses passos no Windows 7 Ultimate 64 bits?
Valeu!
Hello Josivan, I would like to know if you have tryed this steps on Windows 7 Ultimate 64 bits?
xblu
Post by xblu » Mon Feb 11, 2013 7:53 pm
Guys, how do I uninstall dongle drivers of this version, because I would like to install the older version, nn makes me install license maneger
Renan Rocha
Post by Renan Rocha » Thu Feb 14, 2013 12:20 am
Olá
Estou com a seguinte falha:
"O projeto está incompleto. Não foi possível encontrar a biblioteca de símbolos "OS_SYM_ESS" utilizda."
Alguém pode me ajudar?
Grato
Hello
I've got the following failure:
"The project is incomplete. Could not find the symbol library" OS_SYM_ESS "utilizda."
Can anyone help me?
grateful
neethan
Post by neethan » Mon Feb 18, 2013 5:13 am
Hi All,
can't crack ePlab2.2 in Windows7(64Bit). need help forfollowing...
1. Any body have the Part data for ePlan.
2. Crack for ePlan2.2 windows7(64Bit)
TKS
van8x10
Post by van8x10 » Mon Feb 25, 2013 7:45 pm
link EPLAN Electric P8 v2.2 HF1 build 6360:
http://rutracker.org/forum/viewtopic.php?t=4360514
Serg7
Post by Serg7 » Mon Mar 04, 2013 8:33 am
Link EPLAN Pro Panel 2.2 HF1 6360 x86 x64
http://rutracker.org/forum/viewtopic.php?t=4366644
odairrocha-jr
Post by odairrocha-jr » Mon Mar 04, 2013 6:35 pm
Renan Rocha wrote:I've got the following failure:
Can anyone help me?
Você está tentando abrir um projeto criado por esta instalação, ou tentando abrir um projeto criado em outro PC?
Se pegou de outra máquina, veja se copiou o link e a pasta com todos os arquivos do projeto.
Are you trying to open a project that was created in the same PC, or a project created in another PC?
If you get a project from another machine, check if have copy all files, include the folder that have the database of project.
trak_inas
Post by trak_inas » Mon Mar 04, 2013 8:45 pm
Can anyone help me?
Hello the project cold not find the symbol library "OS_SYM_ESS", that is specified in the project.
Check if this library is in the correct folder, usually "C:\User\Public\Eplan\Data\Symbols\(Company)".
If the library is present then you have to change the correct path in the defenitions of the library in the project.
Hope this solve your problem.
Renan Rocha
Post by Renan Rocha » Tue Mar 05, 2013 4:46 pm
Hello trak_inas
My problem was solved. It was necessary make some corrections on the directory of data master for synchronize with my pc.
Thanks for your help.
Renan
jovancha
Post by jovancha » Fri Mar 08, 2013 11:47 am
Hi to all. I've downloaded eplan p8 2.2, installed, followed procedure described by van8x10, but operation was not successful (not_allow). When I ran eplan I receive this message: A suitable dongle is not available for the validation. After first reboot, got message: unable to install usbmultikey, and it's present in device manager as unknown device.
Can someone give precise instruction how to do fresh install on W7 x64 (ultimate), step by step, and provide some screenshots for verification. I see that lots of people are complaining for this dongle problem. In the mean time if I manage to find some solution will share with you.
neethan
Post by neethan » Thu Mar 21, 2013 3:20 am
Dear All,
I still look for sombody's help to crack eplan P82.2 for win7 64Bit. Please help.
Thanks in Advance
odairrocha-jr
Post by odairrocha-jr » Thu Mar 21, 2013 1:27 pm
Did you fallow the steps that van8x10 wrote?
jovancha
Post by jovancha » Sat Mar 23, 2013 9:32 pm
Yeap, step by step. I had to download new dongle drivers from alladin to make it work, only in test mode.
neethan
Post by neethan » Thu Apr 04, 2013 3:49 pm
Following steps given by van8x10. is working.
I have to install D:\EPLAN 2.2(CD-GivenByRittel)\License Client (Win32)\HASPUserSetup.exe
Now ePlan2.2 is working but I am getting the following message while I start the ePlan.
"EPLAN can only be run on your system with reduced performance because of a hardware confict"
error:4521
Please contact your local retailler to fix this problem
How to solve it?
Thanks in advance.
jovancha
Post by jovancha » Fri Apr 05, 2013 5:27 pm
If you have a dongle problem, like me, then you should download HASP driver and update your sistem, described step by step here: http://www.drugdesign.com/web/node/178.
I missed step 4., 8., 9., 10. Then I luched ePlan in test mode and it's working. I'm using W7 X64.
xandaodobraiz
Post by xandaodobraiz » Wed Apr 10, 2013 3:24 am
i've installed Eplan 2.2, but doesnt work crack in Win 7 x64. Please Step-by-step instructions to crack this. I follow all hints in this topic but neither worked.
bjekas
Post by bjekas » Fri Apr 12, 2013 7:57 am
Hi xandaodobraiz,
I've just installed EPLAN 2.2 about 5 days ago. Here is how I did it on win7 64bit:
1 - Install EPLAN (well duh :P)
2 - copy SN-U10066.EGF from crack directory to C:\User\Public\Eplan\Common\
3 - register SN-U10066.reg from crack directory
4 - copy content inside MultiKey64 directory to c:\windows\system32
5 - go to c:\windows\system32 and run install.bat as administrator
6 - now go back to crack directory and run dseo13b.exe as administrator also
7 - activate test mode
8 - reboot
9 - run dseo13b.exe as administrator again
10- Add a digital signature for the driver Multikey. When your asked for the file just write "C:\Windows\System32\Drivers\multikey.sys"
11 - reboot
12 - run EPLAN and choose Professional+ license key. Should run now
Hope it works out for you... I was having a lot of problems with 64bit version too and I figure out that the problem was I wasn't copying the content to system32 directory (step 4) and wasn't running applications allways as administrator and thats very important (especialy install.bat)
Good luck :)
xandaodobraiz
Post by xandaodobraiz » Sat Apr 13, 2013 6:20 pm
lol
Many Thanks bjekas, i'll follow this new step and see whats go happen. Otherwise i post the result here.
See ya and thanks to help
xandaodobraiz
Post by xandaodobraiz » Sat Apr 13, 2013 10:34 pm
Hi Bjekas, i Try your instruction to crack and works, but appear an error, and i dont know whats this. Can you help me?
Screen
Translation to English: due to a hardware conflict, EPLAN can only be run on your system with reduced performance. Please contact your dealer to fix it.
udvaria
Post by udvaria » Mon Apr 15, 2013 9:03 am
Hi all,
error:4521
Please contact your local retailler to fix this problem.
This is a fake message, because you use a software emulated hardware key
Click on the close button, and use it...
But it has a 1 month license only. If you set the system time of the computer forward with 2 months, it will stop working... :(
toos tablo
Post by toos tablo » Wed May 22, 2013 9:51 pm
I want "BeginnersGuide_ProPanel_en_US.pdf" , because this file is not incorrect.
please send for me this file.
Horidol
Post by Horidol » Sun Aug 25, 2013 1:56 pm
i need help
Madman83
Post by Madman83 » Tue Aug 27, 2013 9:59 am
Hello I read already the topic.
I have Win 7 pro x64 in my notebook. If i made the steps how it writed upper. The crack wasn't work.
If i enable the test mode writed 7601 not in 7600.
when i did it in my computer with win 7 ultimate x64. The crack working if i disable the test mode.
Any idea for the win7 pro?
hakanhp
Post by hakanhp » Fri Dec 27, 2013 4:17 am
Electric_P8_2.2.5.6338.part07 is not working help me please.
I have all parts except 07.
hvrsolutions
Post by hvrsolutions » Fri Dec 27, 2013 11:19 am
Hi Sadefa
Thanks for sharing Eplan Propanel .
Can You reloaded Pro_Panel_2.2.5.6338.part08.rar in RapideShare pls?
I have the error message
ERROR: Share invalid. (735d42ea)
And Hotfile is shutdown by the amaerican law
Thanks for any help
Homeroid_BL
Post by Homeroid_BL » Thu Feb 13, 2014 11:26 am
Does anyone here know, how to make work Eplan P8 V2.2 on Windows7 Ultimate SP1 32-bit?
Thanks!
Tadija
Post by Tadija » Mon Feb 17, 2014 9:39 am
I have the same question as Homeroid_BL. I always get message hardware conflict 4521. Does someone have solution?
I am using Win 7 x86 Ultimate SP1 virtual machine.
Best regards,
Tadija
Tadija
Post by Tadija » Wed Feb 19, 2014 8:41 am
I read all answers about installing EPLAN 2.2 and neither one is working. I tried to install EPLAN 2.2 on clean virtual machines XP SP3 (with chinese crack and setup.bat), Win7x32 and win7x64 with all instructions from van8x10, titus95 and bjekas and I always get message when start Eplan: "Because of a conflict Hardware, Eplan can be run on the system only with limited power. [Error 4521].
To resolve the problem, contact your dealer." When I use van8x10 instruction eplan show me message that i have not dongle.
Can someone show right instructions not parcial answers, that works and put on rapidshare all other place crack and other files that need for Eplan. Also if someone who does it, to say what operating system he is using and is virtual machine.
Thank you very much and best regards,
Tadija
zart
Post by zart » Wed Apr 02, 2014 3:17 pm
Hello to all!
Hotfile links is dead.
Please,if it is possible upload Fluid,PPE to another links.
Thank You in advance.
hvrsolutions
Post by hvrsolutions » Wed Apr 02, 2014 6:06 pm
Hi all
Just close the error message and you can work with eplan.
often this message is comming back just close it
Kind regards
hithereS7ba
Post by hithereS7ba » Sun Apr 20, 2014 1:49 pm
Hi!
Since hotfile is down is there a change to get the files from another hoster?
http://torrentfreak.com/hotfile-shuts-d ... it-131204/
Btw, the rapidshare links are still online, but the files are not downloadable because the "file owner's traffic exhausted".
So it would be nice if someone could upload all files to another hoster. Thanks.
djcatalyst
Post by djcatalyst » Wed May 07, 2014 4:48 am
Hi Guys
After successful instalation of Eplan2.2 on mt WIN7 X64 Machine ,
I want to know, is it necessary to keep going with my system on TEST MODE?
thank you
duckman
Post by duckman » Wed May 07, 2014 11:09 am
It will only operate in Test Mode. You can turn test mode off, but have to turn it back on to run Eplan.
DUVAN8
Post by DUVAN8 » Fri May 23, 2014 11:23 am
hi Tadija,
I also have the same problem, any solution had an error 4521?
onosusanto
Post by onosusanto » Sun Aug 10, 2014 2:42 am
Hi Sadefa,
I had tried to open your link about video installation but its failed. shown the file has missing..
could please resend again in gdrive or dropbox..
I have Eplan P8 2.1 and success to install it but how to install Propanel I always getting the problem...
Wait for your reply .. thanks you very much
tepisjrf
Post by tepisjrf » Sun Sep 07, 2014 9:40 pm
Hello everybody.
My proble was that the crack folder downloaded does not include the file dseo13b.exe.
You can download it from.
http://www.ngohq.com/home.php?page=File ... _cat_id=34
http://www.ngohq.com/home.php?page=File ... dwn_id=826
After this, just follow the instruction. Then eplan is running showing the messages about the hardware every time that is starting.
Is important to say that the eplan will run only in test mode, because if you change to the normal mode the driver will not run althougth was signed,
By the way at first time, show me a firewall request, I just denied. But still working. After I have installed and update requested again the firewall esception but then denied both.
Thanks to all the guys whom make it possible.
kielbasa
Post by kielbasa » Tue Jan 13, 2015 10:48 am
Hi everyone on this forum,
I found this thread and decided to ask You here guys.
My problem is similiar however it's not related to the program You described.
In my case I need to crack Wasatch, but the Dongle cracking procedure seems to be quite similiar and that's why i'm here.
I have same problem, that after clicking intall.cmd it says 'devcon failed. no devices were removed'.
What's strange, it worked flawlessly on my laptop, but on my sisters' it didn't. Both have same win 7 x64 installed.
I don't quite understand - is Devcon trying to remove some sort of software from my computer and while being unable to do so, this error pop up appears?
What might be different in both computers?
Maybe You could explain..?
charlie
