[?]: build SCL Code
Mrc2
[?]: build SCL Code
Post by Mrc2 » Fri Jun 22, 2012 4:51 pm
Hallo,
can somebody help me to build scl source code to generate exactly this array structure with
the struct and end_struct lines :?: :?: :?: :shock:
+0.0                D_0            INT                               0
+2.0                D_1            INT                               0
+4.0                D_2            ARRAY[1..1]
*0.0                                  STRUCT
+0.0                   Adjust     BYTE                             B#16#1
+1.0                   Monitor   BYTE                             B#16#0
=2.0                                 END_STRUCT
+6.0                 D_3           INT                                 0
i dont now how can paste a picture for better viewing???
dehell
Re: [?]: build SCL Code
Post by dehell » Fri Jun 22, 2012 7:09 pm
Try this:
DATA_BLOCK DB 4
TITLE =
VERSION : 0.1
  STRUCT
   D_0 : INT ;
   D_1 : INT ;
   D_2 : ARRAY  [1 .. 1 ] OF STRUCT
    Adjust : BYTE  := B#16#1;
    Monitor : BYTE ;
   END_STRUCT ;
   D_3 : INT ;
  END_STRUCT ;
BEGIN
   D_0 := 0;
   D_1 := 0;
   D_2[1].Adjust := B#16#1;
   D_2[1].Monitor := B#16#0;
   D_3 := 0;
END_DATA_BLOCK
Mrc2
Post by Mrc2 » Sat Jun 23, 2012 1:26 am
i try it...
muchas gracias (clap)
