[?]: How to upload program from Panelview-plus-400 by Ethern
hi every one
can any one help me i need to upload program from Panelview-plus-400 by Ethernet but i try to take IP from screen but i don't how and i don't have IP address for that screen and it in run and which keypad give to access to get IP
Re: [?]: How to upload program from Panelview-plus-400 by Et
you can find ip in mode config.
Dear collgl
thanks for your reply and the screen go in run mode when start so how i go to mode configuration on it
so many thanks to you
You can use Configuration_Screen_Utility, which you can read about here or here (temporary mirror) and download an archive of it here or here (I will keep for a while).
This utility allows you to access the configuration screen panel, overriding automatic launching of the project in the panel .
thanks many thanks to you
but if there is way to get in pv+ to see terminal view to get ip addresses and upload program like push f1or f2 while start some thing like that
To enter the configuration mode,for touch screen, you could touch the upper left corner and the lower right corner of the screen simultaneously at startup.
thanks man i used that away to get in pro-face touch screen i hope to tell me in pv+ 400 how i get in terminal configuration to get ip address to upload programcollgl wrote:To enter the configuration mode,for touch screen, you could touch the upper left corner and the lower right corner of the screen simultaneously at startup.
thanks again
at star-up of your PV400+, you can click the small white box when it displays in the lower left corner of the screen to enter the mode configuration.
