i have a S7-200 cpu 226. it has 2 port. port 0 & port 1.
but port 0 is not working (hardware problem).
So i cant communicate with this PLC.
but i have to download the program from PLC.
So how can i download the program from this PLC where port 0 is not working?
[?]: S7-200 port 0 is not working
Re: S7-200 problem
LIke you did it when downloading vio Port0. Each port has his own address, and in Microwin download dialog you will find all devices, among them your 226-port1. Only problem is if you had a HMI connected to port0 - when reconnecting it to port1, you need either change port1 address to one port0 had, either change address of commmunication partner on HMI.
