[?]: Error when run RSLogix5 Emulate
cuongvcs
Post by cuongvcs » Sun Nov 07, 2010 2:44 pm
I have small problem, when start emulate RSLogix5 (i use Version V7.40 CPR9), I setup communication (station ) then I click RUN mode .this error appers ,please see emage Image.
Please help me fix this problem .
this version RSEmulate5 V5.00.08.00 (sos) (sos) (sos)
thank and best regards
neuhauser
Re: [?]: Error when run RSLogix5 Emulate
Post by neuhauser » Sun Nov 07, 2010 11:04 pm
Your problem could be a bug that was in Emulate 5 that would cause it to crash.
This is the patch file released by Rockwell [dead] rapidshare We532.exe
Replace the file in the installed dir. with this one.
From Rockwell tech support:
RSLogix Emulate 5 version 5.00.08 patch (build 5) to fix a crash when opening an RSLogix5 7.0 file.
Question
RSLogix Emulate 5 version 5.00.08.00 patch to fix a crash when opening an RSLogix5 7.00.00 file
Answer
Problem: When opening an RSP file that was created or saved in RSLogix 5 version 7.00.00 (CPR7), RSLogix Emulate 5 will crash.
Solution:
Installing the attached patch file (We532.exe file version 5.0.8.5), fixes the described problem.
Installation:
1.Shutdown RSLogix Emulate5
2.Unzip the attached file and copy it to the RSLogix Emulate5 folder (C:\Program Files\Rockwell Software\RSLogix Emulate 5 by default), overwriting the existing file.
3.Delete the configuration file in C:\WINDOWS\WINEMU5.INI
4.If necessary, restart RSLinx to clear EMU5X.DLL message.
Note: A newer patch is also available from Answer ID 37836 Click Here
cuongvcs
Post by cuongvcs » Mon Nov 08, 2010 7:22 am
thank neuhauser .
I try again and it work.
thank for your help. (tyou) (tyou) (tyou)
sanfre
Post by sanfre » Mon Feb 20, 2017 10:10 pm
Can you update the correction file on another site? Rapidshare is down.
