Hallo,
in first time please sorry for my bad english...
i cant install Step 7 V5.5.
It is the ISO from Rappidshare. I have downloaded it, burn to 2 CD and when i will install on 2 PC (1 PC Step 7 V 5.4 and the second PC is clean) the setup is missing many dll (i have copy these, when Setup asked - from my 3. PC)
after installation the setup abort with Errormessage: Setup cant istall the following Software: Step7.....
Can any help me?
Step7 V5.5 Installation Problem - Installation abort
Re: Step7 V5.5
This ISO write to one DVD
How unpack archive and CD-image (ISO, NRG) files
viewtopic.php?f=2&t=6036
Unpack or copy all files to hard drive folder.
Install direct from hard drive.
Re: Step7 V5.5 Installation Problem - Installation abort
thanks for the answer...
I have copy the File also to harddrive and the same error!
only step 7 is with error install - no ALM...
It must be a other Problem
Provide us with additional information:
- your OS;
- x86 or x64;
- screenshots of errors (at least, first error that you get).
Then it will be easier to solve your problem.
- your OS;
- x86 or x64;
I install from hard disk on Windows XPsp3 32bit with ALM 5.0 without problem.
Thanks,
i will gathering informations in next day but i have the 2 PC shut down.
i hope, we find the Problem.
