Link
- Forum Community
Post
by Link » Tue Feb 10, 2009 4:29 pm
I've DIGSI 4.81 and 4.82 but each version had bigger size about 1GB.
I can't share to you due to my net very slow
If you can download by bit torrent maybe posible for me.
I'm sharing DIGSI4 update V4.82 on the
Torrent link as following:
http://www.demonoid.com/files/details/1 ... 1235029886
Serial
13779-0127-10639
Enjoy download
Link
- Forum Community
Post
by Link » Sat Feb 21, 2009 8:36 pm
SIPROTEC DIGSI 4.82
8x45000 KB + 1x26472 KB
Links:
rapidshare [dead]
SIPROTEC DIGSI 4.82 Devices
13x45000 KB + 1x17486 KB
Links:
rapidshare [dead]
serial number :13779-0127-10639
Klong
Post
by Klong » Tue Feb 24, 2009 7:06 pm
Umencho wrote:Hello
You can use old one
viewtopic.php?t=6201&highlight=digsi
I used and finish with installation successfully. But later after restart the PC and start the program, receive message that needs ALM. I used my home notebook and there I haven't this software. I think that this isn't be usefull but you can try and post the result.
ALM mean Automation License Manager.
If it's posible please install WinCC first after that Digsi.
Please check ALM service by run services.msc, ALM should be started.
I want to see receive message picture, please capture your screen display.
laboul2
Post
by laboul2 » Thu Feb 26, 2009 11:20 am
you can used this serial number :13779-0127-10639 (for digsi 4.7) with digsi4.82 normally without problem
thank you a lot, great job
Umencho
Post
by Umencho » Thu Feb 26, 2009 5:37 pm
Hello
[ALM - A... license man...]
Ok.
Is this works without WinCC/
Maxx
Post
by Maxx » Mon Apr 06, 2009 11:32 am
Thanks to all very much.
I've got DIGSI 4.8, but in this version they use CFC 6.1. Do they use CFC 7.0 in this one?
samedsoft
Post
by samedsoft » Mon Jul 27, 2009 11:54 am
DIGSI PROFESSIONAL + IEC61850 is needed!!!
Also licence and serial numbers if necessary
mohammed yousif
Post
by mohammed yousif » Thu Jun 24, 2010 2:45 pm
I have digsi software vesion 4.82 when I try with the exercise fo IEC61850 and when I insert new object , IEC61850 station and then go to its object properties, appear message on computer screen tale me that " the required license is not installed " . and then I cannot continuouse with this exercise . please can you help me to solve this problem ?
with my respect
laboul2
Post
by laboul2 » Sun Jun 27, 2010 4:32 pm
hello, request DIGSI 4.83 UPLOADED on narod.ru if possible; thank's
focus
Post
by focus » Tue Jun 29, 2010 5:32 am
mohammed yousif wrote:I have digsi software vesion 4.82 when I try with the exercise fo IEC61850 and when I insert new object , IEC61850 station and then go to its object properties, appear message on computer screen tale me that " the required license is not installed " . and then I cannot continuouse with this exercise . please can you help me to solve this problem ?
with my respect
You have to uninstall digsi, and install with this code
10355-0255-58139
segamega
Post
by segamega » Fri Sep 10, 2010 2:42 pm
When i start digsi only this window appears. What's wrong?
Post
by CoMod » Fri Sep 10, 2010 3:58 pm
I have tested with clear
VirtualBox - it work Ok.
mdanijel
Post
by mdanijel » Thu Nov 04, 2010 9:11 pm
Hello, I have installed DIGSI 4.83 with given serial number, but when starting it asks for valid license key
(Message: "No valid license key found. Please install valid license key")
. Did I miss something?
Also installed SP1 and Patch1, nothing changed.
Thanks!
samal_jspl
Post
by samal_jspl » Tue Nov 23, 2010 7:53 pm
Dear All
I can't download the digsi 4.83 file please post a link for the same and obliged.
laboul2
Post
by laboul2 » Tue Oct 18, 2011 1:15 pm
hello all members
digsi 4.84 is now avaible, i have update but i don't have full dvd 4.84 (compatible with windows 7)
update:
http://siemens.siprotec.de/download_neu ... wnload.zip
request full dvd 4.84
laboul2
Post
by laboul2 » Wed Oct 26, 2011 6:35 pm
DIGSI 4.85 update is available
here. It can be installed over DIGSI 4.83.
1. 64-bit operating system support
2. Support of new Feeder Automation Controller 7SC80
3. Feeder Automation Sequence Editor (FASE)
4. Support of new Smart IED 7SJ686
5. Support of devices with multiple system interfaces
6. IEC 61850
6.1. In System Configurator, devices can be renamed without loosing configured static reports (CHDOC00032532).
6.2. Fixed sporadic problems when updating IEC 61850 station with third-party ICD (CHDOC00024520).
6.3. Consistent handling of IEC 61850 Interlocking options in DIGSI Configuration Matrix (CHDOC00032037).
7. Import and Export
7.1. Correct export of PROFIBUS DP system interface (CHDOC00032480)
7.2. Modbus system interface export works correctly (CHDOC00023976)
8. Canceled CFC changes are not transferred into device (CHDOC00030608)
9. IEC 60870-5-103
9.1. Fixed problems with 7SJ/SK devices and IEC 60870-5-103 (CHDOC00026078)
9.2. IEC 60870-5-103 address remains unchanged after download settings (CHDOC00036580)
10. Correct indication of sectionalizer (CHDOC00024675)
11. Correct feeder currents shown during bay out of service (CHDOC00024294)
12. Information about incompatible DIGSI versions is shown (CHDOC00028898)
13. User-defined symbols can be controlled in the control display (CHDOC00024032)
14. Start menu shows correct entries although DIGSI and SIMATIC are installed in parallel (CHDOC00039443)
15. All functions available after MLFB change (CHDOC00037752)
16. Show attributes of USB device (CHDOC00025017)
17. Connection with 7SJ80 works also via USB port (CHDOC00024415)
18. Display of distance zone graphic does not crash DIGSI (CHDOC00040336)
19. Improved compatibility of CFC data types (CHDOC00040585)
Maxx
Post
by Maxx » Fri Nov 11, 2011 8:22 pm
Can anyone reupload DIGSI 4.82???
Please! It's very needed!!
mytom123
Post
by mytom123 » Tue Nov 22, 2011 5:45 am
Hi Guys
I have some problem with IEC 61850 Browser 2.01 that I install in window xp sp3 but I can not run it. For OS Xp sp1, I can run it. So how can I run it in XP SP3?
Brgds.
tuangp
Post
by tuangp » Tue Aug 14, 2012 1:31 pm
I can't install early DIGSI on win 7.
Please up load DIGSI 4.84/4.85 full DVD?
stremson
Post
by stremson » Wed Oct 31, 2012 4:43 pm
serial
13779-0127-10639
10355-0255-58139
Do not work with DIGSI 4.86
I need serial with IEC61850 license for DIGSI 4.86
tak2750
Post
by tak2750 » Mon Nov 18, 2013 9:34 am
does anyone have digsi 5?
or 4.85?
fcakmak2004
Post
by fcakmak2004 » Fri Nov 29, 2013 9:14 pm
Does anyone have digsi 4.86 Serial?
mytom123
Post
by mytom123 » Fri Dec 06, 2013 2:52 am
Try it : 15955-0255-57489
Brgds
fcakmak2004
Post
by fcakmak2004 » Sun Dec 08, 2013 9:09 am
OK.
Thank mytom123 very much...
mahmoud amin
Post
by mahmoud amin » Tue Jan 07, 2014 12:48 am
-please
*may i have serial number for IEC 61850 system configrator v4.87
*digsi 5 software.
KakouSiemens
Post
by KakouSiemens » Sun Apr 06, 2014 1:35 pm
Hi everybody,
I am under Win7 and would need at a minimum the version 4.84. Could one of you post a torrent for version >8.84.
Many thanks in advance,
Update
- Forum Community
Post
by Update » Sat May 17, 2014 3:17 pm
Workaround for installing Digsi update downloaded from siemens site on a clean system.
Tested with digsi v4.89 on Win7 x64, works great. Found this fix on russian forum i'm not an author.
Instructions in side.
Digsi installer
1. Download Digsi update from siemens site ( current v4.89)
2. Extract downloaded zip
3. To folder containing Digsi setup.exe copy instal.dat and 4.87_x32.reg if installing
on 32bit system or 4.87_x64.reg if installing on 64bit system. Rename copied file to sim_reg.reg or modify
install bat accordinglly.
3. Launch install.bat to start setup.
reg import "%cd%\sim_temp.reg"
%cd%\digsi_4\setup.exe -SA
REGEDIT4
[HKEY_LOCAL_MACHINE\SOFTWARE\SIEMENS]
[HKEY_LOCAL_MACHINE\SOFTWARE\SIEMENS\DIGSI4]
[HKEY_LOCAL_MACHINE\SOFTWARE\SIEMENS\DIGSI4\USERINFO_TEMP]
"COMPANY"=""
"EXISTINGPATH"="C:\\Siemens\\Digsi4\\"
"NAME"=""
"SERIALNUMBER"="*****-****-*****"
"UPGRADEDIGSI"="TRUE"
REGEDIT4
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\SIEMENS]
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\SIEMENS\DIGSI4]
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\SIEMENS\DIGSI4\USERINFO_TEMP]
"COMPANY"=""
"NAME"=""
tuangp
Post
by tuangp » Tue May 20, 2014 10:00 am
spak wrote:Workaround for installing Digsi update downloaded from siemens site on a clean system.
Digsi installer
I found the link in siemens site:
http://www.energy.siemens.com/ecc_pool/ ... ate_IC.htm
Link
- Forum Community
Post
by Link » Mon Sep 29, 2014 8:25 am
SIEMENS DIGSI 4.89
torrent
http://rutracker.org/forum/viewtopic.php?t=4833707
Serial key: 26784-0255-37798
thanhpham
Post
by thanhpham » Sun Oct 12, 2014 8:47 am
Does anyone have digsi 4.9 Serial?
thanhpham
Post
by thanhpham » Mon Oct 13, 2014 5:34 am
Can anyone reupload DIGSI 4.86?
laboul2
Post
by laboul2 » Tue Nov 11, 2014 2:16 am
Rheinhardt
Post
by Rheinhardt » Fri Jan 09, 2015 2:58 am
I have installed digsi 4.90 in windows xp 32 bit.
But I cannot connect to siprotec 7sa6111-5mb92 using rs232 through front panel.
Can anyone help please...
hyder
Post
by hyder » Fri Sep 04, 2015 5:11 am
Need DIGSI 4 Professional trial version.URGENT PLZ
nabilafauztin
Post
by nabilafauztin » Fri Oct 16, 2015 11:51 pm
please re upload, digsi 4.XX dead link
tuandtt49dh
Post
by tuandtt49dh » Mon Jun 26, 2017 7:29 am
Hi Everyone
I have a quéstion
Which version of DIGSI 4 compatible with Windows 7 SP1 64 bit and Simatic manager ver 5.5
angel1714
Post
by angel1714 » Sun Oct 31, 2021 12:07 am
It does not allow me to insert an object in the station install the digsi with this serial 10355-0255-58139 how do I solve this please
