[LINK]: SinuTrain v6.0.3 Edition 4 2008 for WindowsXP SP3
Link
Post by Link » Thu Jan 04, 2007 7:11 pm
SinuTrain v6.0.3 2003 for WindowsXP
http://www.siemens.de/sinutrain
SinuTrain - SINUMERIK training systems
Solutions for CNC training:
Control-identical SINUMERIK training systems based on PC for SINUMERIK 810D/840D/840Di with teachware (documentation for beginners) and the corresponding CBTs (Computer Based Training) for ShopMill and ShopTurn.
This package from eMuleNet
ed2k://|file|Siemens.SinuTrain.v6.03.(WIN.XP.mit.Servicepack.1).deutschand.englisch+crack_serial.zip|564995141|85E1AB27047B5DFF857E8E090E41A2FC|/
rapidshare.com [dead] by time
Siemens_SinuTrain_v6_03_2003.part01.rar
Siemens_SinuTrain_v6_03_2003.part11.rar
Link
Post by Link » Mon Jan 22, 2007 2:07 pm
Sinumerik Siemens - SinuTrain 820D / 810D / 840D / 840Di
SinuTrain V06.03 Edition 2 (WIN XP mit Servicepack 1)
Versionsdatum : 28.07.2004
Setup Key: 02105876-FD-S1-0441-302018903
Image ist mit CloneCD gemacht...
For restore the image "SinuTrain V06.03 Edition 2 2004 07 28.img" to CD need use Nero, CloneCD or WinImage...
See Readme.rtf before installation wrote:Installation Instructions SinuTrain 6.3 Edition 2
(WinXP)
This CD contains the following products:
SinuTrain Basic Package including:
HMI Advanced Version 06.03
Sinumerik 802D Version 02.02
ShopMill Version 05.03
ShopMill Version 06.02 Open
ShopMill Version 06.03 Open
ShopTurn Version 06.03 Open
ShopTurn Version 06.04 Open
ManualTurn Version 06.02
DNC-Machine Version 01.00
CAD-Reader Version 06.02
License Manager Version 01.01
SinuTrain Plus including:
AutoTurn Version 05.02
AutoTurn Plus Version 05.02
The functionality depends on the scope of supply (function key).
Only one HMI package can be installed at any one time!
Installation:
1. Before installing SinuTrain, make sure that no HMI version is installed on the computer! Once SinuTrain is installed, do not install any other HMI version.
2. Before installing SinuTrain, make sure that no STEP5-/STEP7 version is installed on the computer (reason: once SinuTrain is installed, the MPI links of STEP5/STEP7 will be lost.).
The License Key must be transferred to the PC prior to the initial start-up of SinuTrain. For this purpose use key SIFLSINUTR0603.EKB in
http://plcforum.uz.ua//S ... _NF_ZZ.ZIP
And check key in ALM after install key.
SinuTrain work in FULL SCREEN or TOP all other windows. Use ALT+TAB keys for select other windows
SinuTrain_V06.03_Edition_2_2004_07_28.part01.rar.....
SinuTrain_V06.03_Edition_2_2004_07_28.part15.rar
This is eMule version
ed2k://|file|SinuTrain_German_Key_CloneCDimage.zip|758279363|37CE2852A53A03A166B3D33FB593C8B3|/
Special language packages for SINUTRAIN V06.03, Edition 2 under WinXP.
http://support.automation.siemens.com/W ... n/21043674
If no serial number
Installed Full Trial version
Link
Post by Link » Sat Aug 22, 2009 7:42 am
SinuTrain v6.0.3 Edition 4 (2008) for WindowsXP SP3
http://rutracker.org/forum/viewtopic.php?t=2126046
Installation:
Before installing SinuTrain, make sure that no STEP5 version is installed on the computer (reason: once SinuTrain is installed, the MPI links of STEP5 will be lost.).
To install SinuTrain, you will need a valid function key. The function key is included when you purchase the SinuTrain CD.
Vorgaengerversion:
V06.03 Edition 3 (WIN XP mit Servicepack 1)
vom 15.12.2005
SinuTrain_Patch
2-26-2008=06.03.21
SinuTrain_Hotfix
2-26-2008=06.03.21/5
Version : V06.03 Edition 4 (WIN XP mit Servicepack 3)
Versionsdatum : 24.10.2008
HMI : V 06.03.23.00
Sprachen : Europa
Czech
Polish
Swedish
Russian
Japanese
Hungarian
Dutch
Finnish
SinuTrain V06.03, Edition 4, must be installed on the PC in order to install the language packages.
Running the EXE file installs the corresponding language package for SinuTrain.
=========== Licensing ================
function key serial number
10549734-FD-A6-451-302410995
Variant 1 (recomended)- License key. Copy hidden system file SIFLSINUTT0603.EKB to hidden system folder C:\AX NF ZZ
Variant 2 - crack. replace "almappapix.dll" from C:\Program Files\Common Files\Siemens\sws
Ввести номер: 10549734-FD-A6-451-302410995
Вариант 1 (рекомендуемый) - ключ лицензии. Скопируй скрытый системный файл SIFLSINUTT0603.EKB в скрытую системную папку C:\AX NF ZZ
Вариант 2 - кряк. Заменить файл "almappapix.dll" в папке C:\Program Files\Common Files\Siemens\sws
Кряк он и есть кряк со всеми возможными последствиями
[dead] by time
Sinutrain_V06_03_Edition_4_2008.part01.rar......
Sinutrain_V06_03_Edition_4_2008.part08.rar
7*100.000.000 + 63.922.876 bytes
======= torrents direct link =========
Sinutrain_V06.03_Edition_4_2008_torrents_direct_link.zip
flopez
Thanks for the post.
Post by flopez » Sun Aug 23, 2009 2:57 pm
Thanks for the post. Tested and works at 100%
flopez
otti.ms
Post by otti.ms » Mon Aug 24, 2009 1:17 pm
Thanks for the links
The license key is available only for ShopMill machine.
I needed a standard for Mill and Turn machine.
No ShopMill or ShopTurn!
agent-cc
Re: [LINK]: SinuTrain v6.0.3 Edition 4 2008 for WindowsXP SP3
Post by agent-cc » Sat Nov 28, 2009 6:12 pm
Link wrote:SinuTrain v6.0.3 2003 for WindowsXP
А как активировать кряк,вначале инсталировать тест версию,а потом как???
С вистой работать не будит???
saravanan_s
Post by saravanan_s » Thu May 13, 2010 7:51 pm
thanks a lot
