[?]: WinCC Flexible 2008 on Panel PC embedded XP
ThermoNuclear
Post by ThermoNuclear » Mon Apr 05, 2010 11:05 am
I installed WinCC Flex 2008 on a $iemen$ Panel PC with XP embedded as the OS.
After i installed the keys with EKB (4096 Tags) but WinCC Flex stays in DEMO mode .
I have the same problem with another PanelPC with a SimanticNet Lean version on it.
Does anyone have a solution.
PS. the install procedure for the embeded XP (unprotect the flashdisk) has also been done.
Please help , this is driving me crazy...
Kind regards
ThermoNuclear
Re: [?]: WinCC Flexible 2008 on Panel PC embedded XP
Post by CoMod » Mon Apr 05, 2010 11:30 am
http://support.automation.siemens.com/W ... n/40237764
ALM also installed ?
What it show ?
http://support.automation.siemens.com/W ... n/23499546
ThermoNuclear
Post by ThermoNuclear » Mon Apr 05, 2010 12:10 pm
Hi ,
ALM V4.0 is installed on the Panel.
Tried to install the license with EKB locally on the Panel -> no luck.
Tried to install on a PG with EKB , than transfer with ALM over the network to the Panel -> no luck.
On the panel i can not see the AX NF ZZ dir for some reasone and EKB says the license is installed.(system dirs are made visible in ControlPanel)
On the panel a textbox with the message that there is no license for WinCC flex keeps
appearing every 5 min. or so.
Please help.
ThermoNuclear
(h)
Post by CoMod » Mon Apr 05, 2010 12:18 pm
How about USB stick with key?
ThermoNuclear
Post by ThermoNuclear » Mon Apr 05, 2010 12:27 pm
Hi ,
also tried with license on USB Stick -> no luck
(wow)
Post by CoMod » Mon Apr 05, 2010 1:35 pm
Show photoscreen with ALM
