Sinumerik Siemens - SinuTrain 820D / 810D / 840D / 840Di
SinuTrain V06.03 Edition 2 (WIN XP mit Servicepack 1)
Versionsdatum : 28.07.2004
Setup Key:
02105876-FD-S1-0441-302018903
Image ist mit CloneCD gemacht...
For restore the image "
SinuTrain V06.03 Edition 2 2004 07 28.img" to CD need use Nero, CloneCD or WinImage...
See Readme.rtf before installation wrote:Installation Instructions SinuTrain 6.3 Edition 2
(WinXP)
This CD contains the following products:
SinuTrain Basic Package including:
HMI Advanced Version 06.03
Sinumerik 802D Version 02.02
ShopMill Version 05.03
ShopMill Version 06.02 Open
ShopMill Version 06.03 Open
ShopTurn Version 06.03 Open
ShopTurn Version 06.04 Open
ManualTurn Version 06.02
DNC-Machine Version 01.00
CAD-Reader Version 06.02
License Manager Version 01.01
SinuTrain Plus including:
AutoTurn Version 05.02
AutoTurn Plus Version 05.02
The functionality depends on the scope of supply (function key).
Only one HMI package can be installed at any one time!
Installation:
1. Before installing SinuTrain, make sure that no HMI version is installed on the computer! Once SinuTrain is installed, do not install any other HMI version.
2. Before installing SinuTrain, make sure that no STEP5-/STEP7 version is installed on the computer (reason: once SinuTrain is installed, the MPI links of STEP5/STEP7 will be lost.).
The License Key must be transferred to the PC prior to the initial start-up of SinuTrain. For this purpose use key
SIFLSINUTR0603.EKB in
Link_is_Dead :(/S ... _NF_ZZ.ZIP
And check key in ALM after install key.
SinuTrain work in FULL SCREEN or TOP all other windows. Use ALT+TAB keys for select other windows
rapidshare.com
by time
SinuTrain_V06.03_Edition_2_2004_07_28.part01.rar.....
SinuTrain_V06.03_Edition_2_2004_07_28.part15.rar
This is eMule version
ed2k://|file|SinuTrain_German_Key_CloneCDimage.zip|758279363|37CE2852A53A03A166B3D33FB593C8B3|/
Special language packages for SINUTRAIN V06.03, Edition 2 under WinXP.
http://support.automation.siemens.com/W ... n/21043674
If no serial number
Installed Full Trial version
