[?] Visam Win32 dongle crack
hi,
have someone a dongle crack for Visam Win32 ?
or mayby for an older version.
it use the hardlock dongle.
thanks so much
boson2k
thanks so much
boson2k
Re: Visam 667
Эта страница содержит загружаемый файл с трояном.
При попытке перейти на нее об этом сообщает антивирус Касперского.
This page contains a downloadable file with a trojan.
When you try to move it reported by the Web-Kaspersky Anti-Virus.
Re: [?] Visam Win32 dongle crack
this not right. the is no trojan insights the image und the image works.
hello,
sorry for late answer, but i have for month no inet.
in the version you have posted is only the ultra light free
have you a dongle crack for this version?
for light and pro version you need a hardlock dongle.
thanks for help
boson2k
thanks for help
boson2k
the pro version was cracked and need no more the dongle.
if you need the visam version 9 please say it.
Hello orionbb,
regarding your above mentioned offer for the pro version I would like ask you if you could share the software with me?
Thank you for your answer in advance.
Best regards
Vansdan
Best regards
Vansdan
hello orionbb,
i tested the version, but so far i remember, the pro version ask for the dongle, but i will test it again to be sure with my statement.
but i would be very thankfull, if you share the cracked version 9
thanks so much
boson2k
thanks so much
boson2k
@orionbb
i am so sorry for my statement.
i tested it again and the pro version works fine without dongle.
i think it caused by a previous installation. after complete uninstall and cleaning the reg it works.
thanks so much and sorry again
bosonk
bosonk
Hello boson2k
which version did you try? Did you try the above mentioned version from orionbb or have you tried an other version?
Thank you for the answer.
Vansdan
Vansdan
@vansdan
yes, i used the version above.
but i hope, that orionbb will share the version 9, because it have a .net converter.
boson2k
boson2k
- Forum Community
- Contact:
Visam 9.00.0007
VisAM Win32 Online (VOK) PRO+
change the file
http://www.share-online.biz/download.ph ... U61KSKR2GZ
change the file
@ orionbb
Thank you for upload the new version but there is still one question.
Which file should i change. I tried to overwrite the file of the 6.67 Version which you have uploaded (this version works... - thanks!) but there wasn´t any changing in the program.
@ boson2k
Thank you for your fast reply!!
@ boson2k
hello orionbb,
i can´t explane how happy i am. thank you, thank you so much!
i don´t have the version 9.00.0007. the only version 9 i could download was 9.0.3(latest at the moment) and the file also works.
but in this version(first time use), i can´t find the .net converter(seem´s it was not active under "project--> send to .net target", only "receive" was active).
then, i try something crazy. i uninstall the 9.0.3 and install the 8.4.9, copy the file from you and.....it works TOO!!!
seem´s it works also with all version 8.
but! this was only a software test, without a plc.
i will test it at the weekend with 2 plc´s and than i would post my results.
but i am sure, that it will work also.
again...thank you so much
boson2k
boson2k
@ orionb
Thank you for the answer, it works fine.
@ boson2k
Thank you so much for uploading the file!
@ boson2k
Hello orionbb,
I don´t have the version 9.00.0007 and so I would like ask if you could upload this version to rapidshare? This would be very helpful for me!
Thank you in advance.
Best regards
Vansdan
Best regards
Vansdan
The link is not valable.
Can you give me a new link
Many thank's!!!!
Many thank's!!!!
- Forum Community
- Contact:
Re: [?] Visam Win32 dongle crack V9
Visam 9.01.0004
change the file and have fun
http://www.share-online.biz/download.php?id=TU76J0ALXIN
Thank's again but nothing running correctly....
I have try with different version of ViSAM, but it's already the same thing.
Have you another version or the right version of you files?
Many thank's again...
Could someone please post a working link to the newest VisamVok.exe again? The links above aren´t working anymore
Thank you very much in advance!
Does anyone have the files mentioned above?
Maybe even those for new Dot.NET Pro?
Pls help me. Thanks
Pls help me. Thanks
