[?]: unitronics m-90 problem with timers.
другие контроллеры
djcatalyst
Post by djcatalyst » Mon Sep 14, 2009 5:26 am
im programing unitronics m-90 .
i have problem with timers .
i've set some timers in my program , but no one of them working.
when i chek the program on run , the timers didnt count the time when im activating them.
help me please . :(
most
Post by most » Mon Sep 14, 2009 10:23 am
it is possible that you are not to make reset in the end of a counting. if to want sends projecto for me, i try to see something
try the samples by unitronics.
also you make a simple project to verify the PLC if function.
djcatalyst
Post by djcatalyst » Mon Sep 14, 2009 10:28 am
tnx for help .
i will upload you the project in couple of hours .. im just not near the plc right now.
djcatalyst
Post by djcatalyst » Mon Sep 14, 2009 7:26 pm
i uploaded the program file
check it out
http://rghost.ru/461963
thanx for help
cmos
Post by cmos » Tue Sep 15, 2009 5:18 am
All your timers have time base and resolution 10 sec ... so they count ... hours. Are you sure that this is what you want? :roll:
djcatalyst
Post by djcatalyst » Tue Sep 15, 2009 8:01 am
no, i want to count in seconds ..
but ive try before to make in seconds .... it doesen't work also
:cry:
most
Post by most » Tue Sep 15, 2009 8:25 am
djcatalyst wrote:no, i want to count in seconds ..
:cry:
the timers function correctly but project is something strange.
1-start with in0
2-to the end of T0_10h start out0 and another timer T1_30h
3-to the end of 30h stop out0 and start another timer T2_8h
4-to the end of 38h start out1
5-to the end of 6,2h stop out1
6-to the end of cicle the project is blocks because T0 is on (?)
it is this that you desire, is OK, the timers working OK
if i have time i can help you, if you say which is the project that you want to make
djcatalyst
Post by djcatalyst » Tue Sep 15, 2009 9:59 am
the program is not finished yet ... ive checked only the timers.
thanx for help man , i will set the timers in seconds & i will look again whats happening.
thanks alot. :wink:
