[LINK]: I need Lenze soft "global drive control"
I need soft "global drive control"
help pls...!
help pls...!
Get actual Update 4.10 from manufucktors page.
http://akb.lenze.de/AKB-englisch/infopo ... enDocument
Info: there is also a SP1 and a GU8...
Create on your PC the following structure
C:\GDC\BIN\GDC32exe
C:\GDC\FBE\FBE.DLL
As files use any file and rename it to the name showen above.
Install update - use parallel installation.
Install SP1 and GU8
Delete helpfolders
C:\GDC\BIN\GDC32exe
C:\GDC\FBE\FBE.DLL
finished
C:\GDC\BIN\GDC32exe
C:\GDC\FBE\FBE.DLL
Install SP1 and GU8
Delete helpfolders
C:\GDC\BIN\GDC32exe
C:\GDC\FBE\FBE.DLL
finished
if you want Global Drive Control Easy v4.5 say something or download with emule (the file is good but not test with hardware)
ed2k://|file|LENZE%20-%20Global%20Drive%20Control%20Easy%20v4.5.zip|40840829|B3DE148C36AA360D0FE5A409EFA7C3CA|h=SYANMS2YFPVMCT3CP7RO62VE27SAAAYR|/
also i have GLOBAL DRIVE CONTROL - V 4.10 SP4 with serial
120760 KB
http://plcforum.uz.ua//L ... .1_SP4.rar
I need GSD
http://support.automation.siemens.com/WW/view/en/113498
http://support.automation.siemens.com/W ... n/23372259
better is to enter in the forum Siemens (register free) and a search for GSD
most
120760 KB
I need GSD
most
GDC
This link informed by most
I downloaded 2 week ago.
planetcla10
planetcla10
