[LINK]: Mitsubishi MR CONFIGURATOR
привода и частотники
flopez
Post by flopez » Sat Feb 02, 2008 10:41 pm
HI
Personal of the forum I am the search of the MR configurator Mitsubishi
thank
flopez
most
Post by most » Mon Feb 25, 2008 7:39 pm
please erase this post
gremlin
Post by gremlin » Mon Feb 25, 2008 7:44 pm
Thank you MOST
i am going to download it now
thanks again its people like you that make this superb forum what it is 100% brilliant
:P :P :P
zafarsalam
Post by zafarsalam » Fri Apr 25, 2008 10:55 am
I am looking for MR Configurator for MR-H350A drive. Can anybody help?
jamrobe
MR-Configurator Serial Number -ID
Post by jamrobe » Tue Aug 19, 2008 11:05 am
Hi all.
From the other links I have downloaded/ installed MR Configurator 81E, 161E, 221EVB1
81E, 161E went OK, but I never worked with them and for some reason on File tab Open, Save and Print are greyed out.
I would like to play with the parameters to see how they look like.
On 221E they are asking for an ID number.
Does anyone has it for sharing?
Kind Regards
Jamrobe
most
Re: MR-Configurator Serial Number -ID
Post by most » Tue Aug 19, 2008 7:20 pm
jamrobe wrote:Hi all.
Jamrobe
see the file in the http://plc.net.ru/viewtopic.php?t=8252
this 221E not need serial (for MR-J3-A e para MR-J3-B )
if you want install 221EVB1 (for MR-J3-T, MR-J3-B Linear e MR-J3-Fully Close) changes the file "setup.inx" of Setup221E for Setup221EVB1 and install.
221EVB1 functions as update of the 221E
or test this file Link_is_Dead :(/s ... x.Link_is_Dead :(
most
jamrobe
Post by jamrobe » Wed Aug 20, 2008 8:31 am
Thanks a lot most
Now it is working, I tested and is OK.
However for 161E on file all menus Open,Save,Print are greyed out.
Do you know the reason for it?
It is because it's working only online?
Regards
Jam
most
Post by most » Wed Aug 20, 2008 7:52 pm
jamrobe wrote: However for 161E on file all menus Open,Save,Print are greyed out.
first open menu parameters ...parameters list ...
for example: loads the values for defect (set to default)
now you can save, print ....
jamrobe
AHA...
Post by jamrobe » Thu Aug 21, 2008 9:00 am
Thousands thanks most.
Works perfect.
My regards to you and all our buddies on forum :D
Jam
