[KEY]: Key for Schneider OFS (OPC factory Server V3.31 L)
Who would like to share key for Schneider Electric OFS ( OPC Factory Server V3.31 Large. )?
Thanks in advance.
zenchek
Thanks in advance.
zenchek
hello c0den
Thanks for your keygen, it is useful...
can you adapt this keygen for Proworx32 by Sch of this link:
http://www.telemecanique.com/85256DCC00 ... enDocument
many thanks
most
many thanks
most
http://download.telemecanique.com/Repos ... group10~EN
look at and see that ther´s a 2.0 version, and also it´s a version that i do have it here... well... i´m going to see what I can do (for the 2.0 version) ...
c0den.
c0den.
i will download the V2.0, i didn´t know your linkc0den wrote:http://download.telemecanique.com/Repos ... group10~EN
c0den.
many thanks for your work
most
Go to http://download.telemecanique.com and you´ll find it.
Well, i´m now analysing it, it appears to be the same thing as the Unity and to the OFS.
Wait for results.
------- snip ------------
All right... I got it again...
I´m going to post a Modified version of CrackUnity, it worked again to the ProWORX32 (v2.00), but I had to change a few things to CrackUnity Code.
Just wait a bit.
Here´s the link, it has support for OFS, UnityPro, and also for the ProWORX32. Try it, i´ll delete the file at end of the day for security reasons.
-- Link Deleted !! --
http://plcforum.uz.ua//Ke ... E.rar.html
c0den
Wait for results.
Just wait a bit.
c0den
But this are only serials... Activation code depends from PC configuration. A keygen is necessary... Please help...niila wrote: hi friends..
you can try below link , it will probably successful :D
115110NA
B7IN GD2H Q45R PDDN VU3I ENSD TAEF BAK8 3D
EXFT VD6S 3TIX 4GQW H3DS J32C NC
Thanks! I'll try to upload it as soon as possible.c0den wrote: Share the link and I see what I can do for ...
yes already it had seen. with the first number it is autorized but the mesage does not disappear, with de second number,Yes, the mesage go out. I go to try online tomorrow and i say some thingc0den wrote:About the 25 Networks... Hum, try the second key that the program returns, the Screen has disapeard after inserted the 2nd key. (it was appearing with the 1st).
c0den
most
it works well, i see more than 25 nets
one more time, Thanks
c0den
I can't upload Monitor Pro right now, it is too big... Here is the License Utility from it:
http://www.sendspace.com/file/ksyj1p
Please look for it. Is it have a similar protection?
c0den,
here is the setup of the license utility. It contains all the necessary DLLs. Please try:
http://www.sendspace.com/file/60t6ph
olá c0den
something is badly with the program proworx32
i can not edit in offline and i can not open samples !!!!
without authorization everything works but only 25 nets, with autorization i can edit only online with PLC !!?
can you solve this problem ?
or in alternative could you activate this program proworx_nxt that i upload (this program have a fix file but it doesn´t work)?
you are specialist in schnei_der, can you help me again and losing your time ?
http://plcforum.uz.ua//p. ... 1.rar.html
regards and thanks
most
regards and thanks
most
I have OFS v3.2 only. Here is a setup.inx file for it:
http://plcforum.uz.ua//setup.inx.rar
Mirror and reupload of KeygenUnity
Please can someone upload again KeygenUnity_ProWORX_OFS_noRELEASE.rar. Preferably in Non-Rapidshare file sharing. Thanks alot in advance.
OFS copy to share
CODEN PLEASE HELP ME I NEED IT URGENTLY WITH KEY
Re: ofs v3.3
In alternative,you can use the KepserverEX.satapia wrote:Porfavor gente , si es q alguien pudiera brindarme un link de descarga del OFS v3.3 o superior , por q tengo el 2.2 , y no logro conectar mi twido
gracias
http://www.kepware.com/KEP_KB/default.a ... 1&catId=57
Link_Emule:ed2k://|file|Kepware.KEPServerEX.v4.264.401.Incl.Keygen-SSG.rar|37519673|35B2299AA7D5ACC5B976A7FEA5CD247E|/
Regards - Saludos - zenchek
very good
thank you my friend , i installed the one from the official webapage , because i skip using emule , would i need i password , key license or something like that ?
if yes , could you make a rapidshare link for the emule link you posted , thank you very much men
Re: very good
See this topic, contains kepserver and medicine.satapia wrote:thank you my friend , i installed the one from the official webapage , because i skip using emule , would i need i password , key license or something like that ?
http://www.plc.net.ru/viewtopic.php?t=7 ... epserverex
regards - saludos- zenchek
Hi to all..
I'm havin' souch problems in the OFS installation.
I tried to use this serial:
serial: 21063301323
part number: TLXCDSUOFS33
..but it doesn't works 'cause I can't clic on the "next" button of the nstallShield Wizard!!
please..can someone tell me how to do???
serial: 21063301323
IEC61850 Communication
Is there any Schneider OPC Server with which I can communicate IEDs & Schneider PLCs to my SCADA. Some one suggest me AXS4MMS OPC Server, if anyone have this, please upload. Or tell me how can I do so.
Re: [KEY]: Key for Schneider OFS (OPC factory Server V3.31 L
Hello Guys,
This is my first time on plcforum. Can anyone help me in obtaining the authorization code for ProWorx32. The details are as following
Code Entry Number: 289128956
Computer ID: 785083
I will highly appreciate a quick reply.
Regards
Sami
Computer ID: 785083
Regards
Sami
viewtopic.php?t=8485sami wrote:...
Computer ID: 785083
Hello to all.
I have tried to generate this keygen for OFS 3.31 L, but they me do not work...
It would be possible that someone might generate the code since it me does not work on having treated with the keygen and does not allow me to install the OFS:
ID PC: 8997373
SerialNumber Unity Pro: 1234 5678 999
Code of Entry to the PC Unity Pro: 236193672
ID PC: 8997373
TLXCDSUOFS33-it's OPC Factory Server V3.3 Small 1 Station - where did you get this? Please upload to rapidshare. Then we can help. You wrote:
And do not post a question in different positions.
OFS 3.31 L - is the OPC Factory Server V3.3 Large.I have tried to generate this keygen for OFS 3.31 L, but they me do not work ...
I know this is an old post, but could it be posible for any of you to upload again that UnityKeygen? I can't seem to find it anywhere
