[?]: Simatic s5 to USB cable schematics ?
molehiya
Post by molehiya » Thu Oct 04, 2007 1:56 pm
Is there any cable schematic that between S5 plc port and PC usb port?
Is it possible to buid my own cable from any schematic?
Thanks...
dante
Post by dante » Fri Oct 19, 2007 7:24 am
No, it's not possible. (it is but will not work!!) There is a "special" hardware (current loops) on the S5 port, so you need a special serial adapter.
Unfortunatelly.
molehiya
Post by molehiya » Tue Oct 23, 2007 5:39 am
Dear Dante,
Pls check the link and see it is possible or not...
http://www.cdelectronic.de/products/S5_ ... g-usb.html
I need the schematic of this cable or any orher .....
dante
Post by dante » Tue Oct 23, 2007 9:04 am
OK, it's a bit trikky. All electronics is integrated into the 15 pin connector; the power supply comes from the PLC port. if U have a look in the documentation will find:
<<PG-UNI-Kabel
• Couples the PC (9pol. COM-interface) with the 15 pole X4/X5 interface port of the plc
• Galvanically separably to 1kV with PG ISO adapter
• Prolongable up to 300 meters
Complete electronics in the plug housing• Supply from the PLC over the current sources of the PG-port
• Functioned also at some CP’s, IP’s and Sinumerik controls>>
so, not possible.
sorry for the bad news.
