[?]: 1747-pic Interface Schematic
molehiya
Post by molehiya » Mon Oct 01, 2007 11:49 am
I need AB 1747-pic interface schematic to make my own slc500/01 and slc500/02 pc - plc cable. Is anybody have it ?
Seinfield
Post by Seinfield » Thu Oct 04, 2007 10:59 am
That will be great, but i have never seen a home made PIC working.
It is a 485 network, but it uses AB propietary protocol.
Just like MPI cables, you can make a PPI cable, it is only rs232 -> 485 but MPI uses special commands included in the cable.
molehiya
Post by molehiya » Thu Oct 04, 2007 1:47 pm
Thank you.. I will not waste my time to search this schematic anymore..
molehiya
Post by molehiya » Thu Oct 04, 2007 1:51 pm
One more question...
Is it possible to make " home made usb cable " for slc500 plc series? Any schematics about that?
Thanks for your replies..
MareBlu
Post by MareBlu » Fri Oct 05, 2007 5:11 am
Two years ago I've seen this article somewhere (I don't remember the site):
If you personal want to play around with AB SLC500 without buying the PIC from AB, you can make one in cheaper price. The following is what you need:
a) RS232->RS485 converter. I'm using IC-485SI.
b) RJ45 plug.
c) min. 4 core screen cable for connecting between the Converter and the RS45 plug.
i) Connect terminal 1 (T+), terminal 4 (R+) on conv. to pin 1 of RJ45.
ii) Connect term. 2 (T-), term. 3 (R-) on conv. to pin 2 of RJ45 plug.
iii) GND on converter to pin 4 & 7 of RJ45 plug.
iv) Shield connect to pin 6 of RJ plug.
Crab the RJ plug upright with the metal connector facing you, Pin 1 to 8 is counting from left to right.
Turn the switches on the converter to DCE and T-RTS/R-RTS.
It works fine with SLC500/01 through RSLinx and RSLogix500.
Good Luck.
Seinfield
Post by Seinfield » Fri Oct 05, 2007 8:37 am
"Each SLC 5/01 processor has a DH-485 port for programming and processor-to-processor communication initiated from the other node."
So it only needs a 485 converter, it will not work with the others SLC unles they are first configurated as DH485.
If the ports are not configured as 485 or RS-232 you will need the PIC.
"SLC 5/02, SLC 5/03, SLC 5/04 and SLC 5/05 processors have communication ports (Ethernet, DH+, DH-485, or RS-232-C) that can initiate communication."
LdSwFyL
Post by LdSwFyL » Wed Feb 20, 2008 8:39 pm
You can download 1747-PIC PCB and Diagram here http://plcforum.uz.ua//17 ... B.rar.html
It includes a Spy port to ripe PLC password if you have ploblems asked me raphbarj@yahoo.com
molehiya
Post by molehiya » Mon Feb 25, 2008 8:28 pm
I can not open the 1747_PIC_LdSwFyL_pcb.pcb file.
Please help me which software can open this file...
gregar
Post by gregar » Tue Feb 26, 2008 12:38 pm
Soft for open .pcb
1. PCAD
2. Pview_X5 SPR
3. A Free Gerber Viewer
4. PCB Layout Check Design Rule Template (Top Tec PCB Ltd.)
5. Print Shop Deluxe Business Card
6. Protel Technology Advanced PCB Design
7. PowerPoint Application Data File (Microsoft)
8. PC-Doctor File
9. PADS Printed Circuit Board (Mentor Graphics Corp.)
10. Ivex Winboard Design File
11. Broderbund Print Shop Business Card
12. ACCEL or Protel Printed Circuit Board File
13. ExpressPCB Printed Circuit Board Layout (ExpressPCB)
molehiya
Post by molehiya » Fri Mar 07, 2008 8:53 am
I have tried all the softwares and i cant open the file...
