Good morning, I just want to ask for some help on how to gather data on other s7300 cpu w/out using cp.
Is it posible to get using profibus DP only?
Do I need some Standard FC? Please, your help will be much appreciated.
Thank you very much in advance.
[?]: s7-300CPU to s7300CPU Communication using DP Only?
hello,
look at modul d10 http://www.automation.siemens.com/fea/h ... module.htm
Thanks Pracker, I think I should try this too. It looks interesting. By the way, if I'm going to transfer many data does it means that I need to repeat to call this sfc's in my ladder editor, because i think it only transfer 1 byte per call. And I can't undrstand that much what should I put on the parameter LADDR? If you don't mind Can I have snapshot on where you get this address when you program this? I think I 'm taking some of your precious time but your help will make me a better one in my chosen field. Thank you.
Thank you very much.
Warm regards,
Rey
Warm regards,
Rey
