[?]: ACAD 2006 work time expires !
Тools, Elcad, Eplan, ...
gremlin
Post by gremlin » Sat Mar 29, 2008 6:40 pm
Does any one how to get the licence to work in autocad 2006 it was a cracked version but now as of last week it says the licence file is out of date !
any ideas
regards
gremlin :oops:
makalex
AutoCad 2006 serial+keygen!
Post by makalex » Mon Apr 28, 2008 9:06 pm
I would like to ask you if someone can provide me with working serial number and key generator for AutoCad2006!
The ones which I have are not working any more!
When I try to run the existing key generator the message says "Windows has encountered a problem and needs to close", does some one has an idea what can be the problem because when I had installed the program for the first time everything has worked fine.
I need this information very urgently!
Thank you very much!
All the best.
gremlin
Post by gremlin » Mon Apr 28, 2008 9:10 pm
try running the keygen on a difforent pc and noting down the number generated ratehr that cut n paste
Dreamer76
Post by Dreamer76 » Wed May 21, 2008 8:36 pm
huhu gremlin
had the same problem... i update to the new version 2008....
ciao
dreamer76
