Spac Automazione 2019
Тools, Elcad, Eplan, ...
xblu
Post by xblu » Thu Dec 06, 2018 9:48 am
SPAC Automation
The main features
Management of projects and multi-sheets, without page limits, with full elasticity and speed of work in sheets and between sheets
Multinormative graphic symbols (IEC, VDE, JIC, Unifilare, Electronics ...)
Fluid / Pneumatic Schemes
Graphic libraries Drives / Inverters / Modules
Rapid symbol creation suite
Powerful and fast commands for multi-wire and single-line design
Numbering of the conductors both in semi-automatic and automatic mode with possibility of marking according to IEC 391 standards
Insertion of terminals and connectors with processing of the connection terminal blocks also including equipotential terminals, splitters and multilevel
Global cross-reference of the scheme with detailed navigable diagnostics
Dynamic navigator to quickly identify components on the schema
Graphic library symbols PLC cards (2D and 3D) of the main manufacturers
Design of PLC I / O based on database and dedicated graphic symbols with import / export of the bits used
PLC drawing starting from a configuration or from an I / O list file in Excel
Combination of product codes with Drag & Drop from the complete material database of the major brands in the sector and fully customizable
Material database constantly updated and synchronized online via SPAC Data Web (requires service contract)
Generation of bills of materials with configurable outputs both in design and in files
Generation of documentation of the materials used in the project starting from technical sheets in .pdf format
Use of bills of materials prior to planning
Export of labels. Components, Conductors, Clamps to marking systems
Bill of materials for multipolar wires and cables
Wiring table of the electrical panel
Routing of wires in the electrical panel to calculate the length of the conductors with analysis and optimization of the paths
Automatic generation of the scheme by choosing the machine configuration
Drawing of the carpentry of the electrical panel both external and internal with accessories
Assisted drawing of the topography of the electrical panel by means of drag & drop from the list of components to be placed on the plate
Automatic drawing of the push button layouts (front and back)
Plant layout design
Loop Diagram - list of the connection points of a component from the machine edge to the electrical panel
Overtemperature calculation of the panel
Export of the project data in Excel and return of the same after modification
Sheet revision management to save and restore project situations
Prints and generation of dynamic navigable .pdf complete with materials and links to online technical data sheets
Bidirectional data exchange interface between P & ID diagrams (EsaPro) and wiring diagram
Data exchange interface with Cabling module for the
xblu
Re: Spac Automazione 2019
Post by xblu » Thu Dec 06, 2018 9:50 am
someone good, can create a crack (oo)
maverik53
Post by maverik53 » Fri Jan 04, 2019 5:46 pm
I have the dng file of working key for spac 2019
Who Help Me to create emulator?
Tank You
DNG file here
https://mega.nz/#!SUIyWQ7b
PLEASE HELP ME
Tank You
maverik53
Post by maverik53 » Tue Jan 08, 2019 8:30 am
roberto_battistella
Post by roberto_battistella » Wed Jan 09, 2019 7:34 pm
scusate, ma a cosa serve il file dng ?
sorry, but what is the dng file for?
EPLSG
Post by EPLSG » Thu Jan 10, 2019 9:00 am
Hi all,
sorry maverik53 are you Italian?
About dng file:
Normally we use bin file to make dongle key for a lot of software. We tried to make bin file for spac but we were not able.How did you do it?
With bin file we can create a virtual dongle.
Keep in touch (gpost)
maverik53
Post by maverik53 » Fri Jan 11, 2019 1:46 pm
EPLSG wrote:Hi all,
About dng file:
Hi All
Yes, I'm Italian.
I only found a program to dump the hasp key and generate the dng file.
Can you tell me if there is any other program to generate the bin file?
EPLSG
Post by EPLSG » Fri Jan 11, 2019 2:06 pm
Can you explain me wich was the procedure to create dng file?
We have tried with HUSPHL2010 but never was create,bin file was enpty.
We think the problem is in the key,probably spac key is undunpable.
If you want I send your dng file to other people to try to dump.
This process include a test version for 1 week but after working you have to pay.
Keep in touch
xblu
Post by xblu » Sat Jan 12, 2019 1:20 pm
No news
xblu
Post by xblu » Wed Feb 13, 2019 12:16 pm
guys then no news, some good help us (oo)
antozu89
Post by antozu89 » Thu Feb 28, 2019 8:51 pm
Hi to all... Can anyone give me a link to download the latest cracked version of SPAC Automazione? (sos)
frekdz
Post by frekdz » Sat Aug 03, 2019 11:25 am
can help to emulate yours dongle
xblu
Post by xblu » Fri Jan 24, 2020 12:17 pm
Guys no news (wow)
Razer1987
Post by Razer1987 » Wed Feb 19, 2020 4:40 pm
was you guys able to makes something more recent than spac 2011 work?
