clock.zip пояснения // explanation
примеры программ
Post by sania » Sun Aug 28, 2005 6:14 am
RUSSIAN
этот пример использования системных часов S7 делает пульсы 100мсек,1сек,1мин,1час,1день.
в проге можно не использовать таймеры,просто складывание:
L DB10.DBW0
L DB5.pulse_1sec
+I
T DB10.DBW0
L 50
=I
JBN M001
S M0.0
L 0
T DB10.DBW0
JU M002
M001:R M0.0
M002:NOP 0
так же есть вывод сист.часов на HMI и возможность их уставки с HMI по часам компа
ENGLISH
this example of use system clock S7 it makes the pulses of 100msek, 1sek, 1min, 1hour, 1day.
in program it is possible not to use timers, is simple the storing:
L DB10.DBW0
L DB5.pulse_1sec
+I
T DB10.DBW0
L 50
=I
JBN M001
S M0.0
L 0
T DB10.DBW0
JU M002
M001:R M0.0
M002:NOP 0
so is a conclusion of system clock on HMI and the possibility of their setting with HMI on the clock of the controller
Maxime
System Clock
Post by Maxime » Mon Oct 30, 2006 6:47 pm
I don't understand why you should use such a program if you could use Clock Memory Bit and then have enhoug pulses (8) which you can prolongate with timers. You only have to say which Memory Bit you use in the hardware config.
greetz
