[?]: WinCC Flexible 2007 and more 2048 tags
Victor Yeo
Post by Victor Yeo » Sun Jul 06, 2008 3:25 pm
Why when I active runtime (PC Runtime), License in ALM cannot active (Runtime 2048 installed ) and always popup message
Runtime wrote:"Runtime have more than 2048 tags "
How with Key License Runtime WinCC flex 2007 8KTags ?
and why the License manager active when I running WinCCflex in configuration (WinCCflex Advance checked in ALM ) and not active when I'm running in Runtime mode (not checked in ALM)
Post by CoMod » Sun Jul 06, 2008 4:46 pm
Victor Yeo wrote:why the License manager active when I running WinCCflex in configuration (WinCCflex Advance checked in ALM )
Flex Runtime sends inquiries about a runtime key to ALM each 30 minutes
Victor Yeo
Post by Victor Yeo » Sun Jul 06, 2008 10:30 pm
Thanks for your email, I'm test ,and replace the key license WinCCRuntime 2048 with test license WinCCRuntime 8192,
but when I'm test runtime, same popup message
Runtime wrote: "To many tags have configuration"
I think name SIFLA9XRP30102.EKB for WinCCRunitme 2048,
can you rename original SIFLA9XRP?????.EKB for WinCC Flexible Runtime .
(I don't know file name original key license WinCRuntime for more than 2048 tags)
in ALM I'm check this license OK!,
when Runtime running have popup
"to many tags ..."
Dreamer76
Post by Dreamer76 » Mon Jul 07, 2008 2:40 pm
you cant run more than 2048 tags
i never saw a project with more than 2000 tags.... :?:
what kind of projects will you program?
ciao
dreamer76
Victor Yeo
Post by Victor Yeo » Mon Jul 07, 2008 4:00 pm
Dreamer76 wrote:you cant run more than 2048 tags
I have project have 2149 Tags, because my project convert from proTools file (MP370) to PC Runtime
Post by CoMod » Tue Jul 08, 2008 1:20 pm
You need optimize your tags table
Many PLC addresses have 2 names and more
is very bad style to use 1 PLC memory word how 40 different WinCC Flexible tags
Whether it is possible to use more than 2048 tags or not?
I while cannot answer this question.
Надо внимательно относится к таблице тэгов.
Многие PLC адреса имеют 2 имени, а многие и более повторов.
Хватило терпения сосчитать - 40 тэгов для слова MW0.
Можно ли использовать более 2048 тэгов или нет ?
На этот вопрос я пока ответить не могу.
Victor Yeo
Post by Victor Yeo » Tue Jul 08, 2008 3:32 pm
Dear Comod
Oke Thanks for your explain, I think i must be correct all tags and I hope this project after correct, have under 2048, but I hope if the other project have more 2048 , I have license 8KTags WinCCflex Runtime 2007
Thanks for all
Post by CoMod » Tue Jul 08, 2008 3:40 pm
Victor Yeo wrote:..., but I hope if the other project have more 2048 , I have license 8KTags WinCCflex Runtime 2007
Thanks for all
but we wait Flex 2008 in next mont
It is very difficult to see the message on an error of the license in the Flex Runtime.
It unexpectedly appears and quickly disappears.
I do not have not enough patience to wait the message...
in Russian wrote:у меня не хватает терпения ждать сообщений об ошибках лицензии от Flex Runtime - они неожиданно появляются и быстро исчезают.
Ждём новый Флекс 2008 в следующем месяце.
