[?]: WinCC Flex 2008SP3 not support ProTool projects migrati
After installing WinCC Flexible 2008 SP3 Upd2 of projects Step7 disappeared ProTool projects. How to return the support of ProTool in Step7? "Integration to Step7" from the File menu in ProTool does not work!
Re: [?]: WinCC Flex 2008SP3 not support ProTool projects mig
http://support.automation.siemens.com/W ... n/57267466
Decision: Use http://www.VirtualBox.org with WinCC flexible 2008 SP2ProTool Migration:
Because of the neccessary changes for the 64 Bit support under Windows 7, the ProTool migration cannot be offered any more with Service Pack 3 for WinCC flexible 2008.
В связи с необходимостью писать 64-битную версию конвертора из Протула под Флекс Сименс принял решение не писать такой конвертор и просто выкинул эту опцию из Service Pack 3 for WinCC flexible 2008.
Для преобразования старых проектов Протула во Флекс используйте виртуальную машину с установленными старыми версиями программ.
Problem not in migration, but opening projects with ProTool!
As suggested above needs to have non SP3 of WinCC FLex 2008 installed. And in case of 64 bits platform a virtual machine is a way to manage it.
BR
BR
