Dear Colleagues,
Good evening, I just want to ask what will i need to monitor power consumption. (Voltage of 440V,220V) I like to monitor it in Wincc or other siemens PC base or non PC base system.
What also other field devices i need to consider prefferably siemens also.
Thank you very much in advance.
Warm regards,
[?]: 440V,220V Voltage Power Monitoring
Re: [?]: 440V,220V Voltage Power Monitoring
https://www.energy-portal.siemens.com/s ... kg775.html
using PROFIBUS or MODBUS protocol
https://www.energy-portal.siemens.com/static/au/en/products_solutions/1001040_7kg775.html
You have also SENTRON PAC power meters from Siemens
http://support.automation.siemens.com/W ... reeLang=en
https://www.sea.siemens.com/us/Products/PowerDistribution/Product/ACCESS-Power-Monitoring/Product/Datasheet-Manual/Pages/Sentron-4200-Basic-Power-Meter_D__M_Landing.aspx
