Unlock S7 200 smart PLC
peterfrick
Post by peterfrick » Thu Dec 06, 2018 9:53 am
Does anyone know how to password unlock S7 200 smart PLC SR40/CR40. Please help.
woanxh
Re: Unlock S7 200 smart PLC
Post by woanxh » Sun Dec 09, 2018 12:43 pm
Hello, I also want to know 200smart unlock. Have you got the answer
woanxh
Post by woanxh » Sun Dec 09, 2018 4:20 pm
The Chinese have found the crack to clear the 200smart password and then they can't get the password. They used the software to clear the password
peterfrick
Post by peterfrick » Tue Dec 11, 2018 7:06 am
No not yet, still waiting if someone can crack it. Which Chinese Site is doing this?
peterfrick
Post by peterfrick » Sat Jan 18, 2020 7:11 pm
Any update on this. Can anyone unlock s7 200 smart plc?
Post by CoMod » Sat Dec 12, 2020 7:11 am
I delete link of new user to chinese site with this info
Siemens S7-200 SMART decrypted successfully, level 4 password POU encryption can also be cracked.
For SMART password cracking... The software is priced at US$30,000 globally.
(h) (boom) (oftop)
I think S7-1200 is now the best choice for use in small projects ... and in order not to quack projects = do not order them in China :) (h)
я думаю S7-1200 сейчас лучший выбор для использования в небольших проектах... и чтобы не крякать проекты = не заказывайте их в Китае :)
https://translate.google.com/translate? ... p?id%3D107
https://translate.google.com/translate?sl=ru&tl=en&u=http://www.plc4good.org.ua/view_post.php?id%3D107
Is it easy to unload a program from an S7-200? Or not really?
Phase six - learning the code from the Middle Kingdom.
The control program, in fact, is nothing tricky.
The usual "relay" control of all sorts of things, such as hydraulics, pumps, valves and other rubbish, but ...
There is a timer code for 360 work shifts of 8 hours.
The timer counts only when some output is turned on, such as turning on the hydraulic pump of the pressure amplifier, that is, when the machine is running.
When the timer counts down to the end, the flag with the address M13.0 is set :), like, all guys, pay money!
What is this if not extortion! It is impossible to clear the flag in any way, except for connecting the debugger, which requires a password!
How ugly it is and who programmed it, either the Chinese or our intermediaries from Moscow, I, of course, do not know ...
But I want to say: Well, you guys are goats!
PS: Interestingly, 360D is written on the PLC case with a marker. At first I took it for a password, then, of course, the real meaning of this inscription became clear :).
By the way, the first version of the programmer was most likely a working one.
This rotten stub of a mouse cable was to blame!
http://www.plc4good.org.ua/view_post.php?id=107
Выгрузить программу из S7-200 просто? Или не очень?
Sam N
Post by Sam N » Sun Aug 08, 2021 10:09 am
выгружайте программу из eeprom- ки
так же можно переносить программу в новый чистый контроллер
