Page 1 of 1
[Scheme]: Trend-Controller IQ3XCITE
Posted: Fri Oct 17, 2008 11:58 am
by FLETCHER
Trend-Controller IQ3XCITE with software set 6.
I'm trying to download one program to this controller with lan connection.
I set up the addres IP and it responds ok to ping with crossover cable, but i cannon download or upload nothing the connection fails all time.
Is needed the serial cable rj11-db9 for made this?
I agree some help with the connection support.
Posted: Fri Oct 17, 2008 1:10 pm
by vlad2006gr
For RJ11 - DB9 ADAPTOR see http://www.jdstechnologies.com/download ... pinout.pdf
Good luck!
Posted: Mon Oct 20, 2008 7:09 am
by FLETCHER
Thanks for your suport.
But are you sure that is the same schema for trend controls.
Posted: Mon Oct 20, 2008 8:17 am
by vlad2006gr
Trend-Controller IQ3XCITE has standard EIA-232 port
See http://ntc.novarcontrols.com/Products/I ... 3XCITE.pdf
and http://www.rkg.cz/uploaded_files/ke_sta ... ite_aj.pdf
RJ11 for IQ3XCITE :
1 RX
2 +24v
3 CTS
4 RTS
5 0v
6 TX
Good luck!
Posted: Mon Oct 20, 2008 10:36 am
by FLETCHER
Is this I assembly it now and I tell You something.
Is not rj11 is rj12
Posted: Mon Oct 20, 2008 1:03 pm
by FLETCHER
The solution is in the last picture it works ok.
Trend IQ3xcite RS232
Posted: Sat Jun 06, 2009 12:20 am
by thermal
I know this is a long time back now:
the datasheet listed above, table at bottom of page 18 says only text comms via 232, not download.
This is also on page 24 of latest datasheet.
Interested to know if you did get it to communicate enough.
Do you not have SET programme & product key?
we need a friendly in here to crack SET :)
Re: [Scheme]: Trend-Controller IQ3XCITE
Posted: Fri Aug 28, 2009 6:29 am
by autogeek
I am looking for a copy of the SET6 software? can you help me? where do you find it?
Thanks!
Posted: Thu Feb 04, 2010 8:48 pm
by saad rashed
MY DEARS I NEED THE SOFT SET 6.X
THANKS ALOT
Posted: Tue Apr 11, 2017 7:21 pm
by caspyro
hi did any one ever get SET software ?
Posted: Mon Feb 11, 2019 10:14 pm
by caspyro
hi i now have two versions of SET but no registration if any one want to hav a go with it and gets it working let me know
https://mega.nz/#!vrxU3A4T!NvSdgPuhsT-O ... 4Spq3Bbz04
Posted: Mon Feb 11, 2019 10:15 pm
by caspyro
