Hi Everyone!
Hope you are fine. I have a Machine which consist of Q series Mitsuibishi PLC and Mitsuibishi E700 VFD which is Connected with CC Link Module of PLC. 2 to 3 days ago one of the inverter becomes faulty so I replace it with another which is working fine but when I installed this VFD so its not going into run state however I have check and connected all the wiring but the main problem is this inverter in not going in Run mode and it is directly linked with CC Link cable and connected in parallel with other VFD. So my question is how can I solve this problem from where I will check ?? . And I have aslo Check all the signals coming from the PLC program. Please guide me in this Regards. I will be very thankful to you.
