I need the drivers for Fatek plc programming cable. The cable type is FBs_U2C_MD_180. Are the drivers compatible with winXP and win7?
Fatek plc cable drivers
Have you tried PL2303 drivers?
Re: Fatek plc cable drivers
FBs_U2C_MD_180-communication converter cable with standard USB AM connector to RS232 MD4M connector (used in standard PC
USB to FBs main unit Port0 RS232). You can use the USB converter in RS232,
for example UPort 1110 - http://www.moxa.com/product/UPort_1110.htm
1-port RS-232 USB-to-serial converters.
Pinout Fatek Port0 RS232 - http://www.thaiservo.com/thaiservo/User ... manual.pdf page 191.
Drivers XP- http://www.esea.cz/support/fatek/PL-230 ... taller.exe
Drivers Windows Vista, Win7, Win7(64bit) -
http://www.esea.cz/support/fatek/vista- ... apters.zip
http://files.beijerelektronik.com.tr/do ... dows_7.zip
http://files.beijerelektronik.com.tr/do ... dows_8.zip
-yes.dimz wrote:Are the drivers compatible with winXP and win7
