DEAD ERROR No. 305
другие контроллеры
ernandef
DEAD ERROR No. 305
Post by ernandef » Wed Aug 10, 2016 11:49 pm
Hello!
After power on my plc (Schneider Quantum - 140 CPU 65150) i get this info on lcd screen.
DEAD ERROR No.305
Does any one know the meaning of this error code?
Thanks!
SE_support
Re: DEAD ERROR No. 305
Post by SE_support » Mon Aug 15, 2016 8:41 am
Hello ernandef,
in most cases you need to check/replace your power supply (140CPSxxxxx).
ernandef
Post by ernandef » Tue Aug 16, 2016 7:46 pm
Hello SE_support !
I solved this issue on other way. I opened my cpu and cleaned all connections inside. After that, the problem was solved.
Thank you!!
SE_support
Post by SE_support » Wed Aug 17, 2016 6:58 am
ernandef wrote:Hello SE_support !
Thank you!!
really strange solution :) May be you had luck. Thanks for feedback!
