Hello all,
I have got problem with my ENET module. Generally, I want to get this effect:
http://www.youtube.com/watch?v=-_Itjr-tKFE
It is Modbus Droid, an android application which can connent with PLC (by modbus i think ;p). My knowledge about PLC's, protocols etc. is not large, so I please your understanding.
Somewhere i found tutorial how to configure ENET module, but author used port 5551. It worked good, I could send ladder to PLC, but i can't connect with Modbus Droid app. Later i foud informiaton that is special dedicated port, and only GX Developer and mitsubishi devices use it. I also found information that ENET blocks (?) ports under 1024. This explains why men on the movie use port 1025 (not 502 modbus port). So i think its possible to do, but i need to know how to configure this module correctly.
I will be greatful for all the tips. Greetings
Mitsubishi FX3U+ENET module configuration
Re: Mitsubishi FX3U+ENET module configuration
the FX3U-ENET-P502 block is necessary
Are you sure? Man on the movie use port 1025, not 502...
I did such much earlier that person.read manuals
With all respect You are wrong. I used special function block in gx works 2 and everything works great. Greetings
fine.why then you ask questions
I found it yesterday. Maybe someone will have the same problem in future
