Hello All,
I want to know how to configure the PLC with the software programming CONCEPT V2.6 Release 7 for the CPU will restart at hot "processing".
The CPU is 434 12a
another question? I would like know if it is possible to logging with Unity Pro V7 for download the Concept Program inside the CPU
"140 CPU 434 12A"
Thank you in advances
CONCEPT V2.6 R7- How to configure the Reboot(restart) in hot
Re: CONCEPT V2.6 R7- How to configure the Reboot(restart) in
Sorry, dont' understand your first question.
Second question: you can flash concept firmware to the PLC and work with concept, or you flash Unity Firmware and work with UnityPro Software. If you have old concept you can also convert it to UnityPro with Concept converter.
BR
BR
