I am beginner in 800xA ... and have request
I installed single node with software controller.
You can see that computer status for my single node is bad.
How can I solve this problem? Is it important for functionality my single node?
Thanx for help
Best regards
Roman
800xA: Single node status
Re: 800xA: Single node status
First you should answer the question: for which purpose did you load "PC Network and Software Monitoring" system extension into your system?
Then I can answer whether "Bad" status is important for your system or not.
Check OPC Data Source definition aspect in the IT OPC Server network that it is connected to the service group (default "SG_IT Server")
If OPC Data Source definition aspect is configured - go to "IT Device Manager" aspect of your node object (800ENGNODE). Click "Populate" and recheck node status.
Thx for answer. Linkinx64 you are invaluable.Linkinx64 wrote:First you should answer the question: for which purpose did you load "PC Network and Software Monitoring" system extension into your system?
It is my single node installed on virtual machine for training so I installed many extensions ...
I think that service is configured properlyLinkinx64 wrote:Check OPC Data Source definition aspect in the IT OPC Server network that it is connected to the service group (default "SG_IT Server")
I clicked "Populate"Linkinx64 wrote:If OPC Data Source definition aspect is configured - go to "IT Device Manager" aspect of your node object (800ENGNODE). Click "Populate" and recheck node status.
but computer status on faceplate still is bad
but Device status probably is OK (green colour)??
thx for help
