GX-Configurater-ad & pt requires
friends i need GX-Cofigurater-AD v1.10L or any version, can anyone help me
Re: GX-Configurater-ad requires
thanks friend and i also need gx configurater-pt for programing the qd62e module can it possible
Re: GX-Configurater-ad & ct requires
friend i'm having qd62e by using which software can i able to configure, gx configurater-pt or gx configurater-ct
thanks friends i need gx config ct v1.10l or later for programming the qd62e please help
Re: GX-Configurater-ad & pt requires
friends i'm facing three problems:
I'm using qcpu q00u,1input module,1o/p module,1analog module,1comm module,1high speed encoder module.
now i'm facing problem in cofigurating the analog module
1.fb conversion is not happening while opening the intelligent function utilities.
2.i can't able to access the buffer memmory or not able to write or read from the buffer memmory.
3.if i enter that buffer memmory address in the "mov" instruction its giving error about device memmory error.
what i have to do anyone please help me.
also i need gx configurater ct v1.01L or later for configuring the encoder module qd62e.
Good afternoon.
Please share GX-Cofigurater-AP.
