unPassword CodeSys library
[solved] Is Possible to unpassword ABB CoDeSys User Library?
I have a ABB AC500 PLC and project files writed with CoDeSys V2.3
when I open the project with CoDeSys, a pop-up windows shows for asking input a password.
this is the codesys library file
http://depositfiles.com/files/8c9pr0r30
Is there some tools can unpassword the file ?
or somebody who could help me to get the password?
Thanks all .
Thanks all .
Re: [help] Is Possible to unpassword ABB CoDeSys User Libra
and this is another user library file:
http://depositfiles.com/files/zhwaarg0f
when I opened the project file which reference this library file,
NO pop-up window show for inputing password,
directly shows a error window, the error information is as follow:
The following libraries could not be loaded.
heroctol.lib*2.9.10 14:31:16
. . . . . . . | OK|
who know what's the problem ?
Thanks all, again
. . . . . . . | OK|
Thanks all, again
It is possible to unpassword, but... the popup dialog asking not for a password. It asking for a KEY.
This library was saved as an external encrypted library.
So this is not just "black box". As a result - library can't be added to project without entering that key.
I guess you see the error window because of that.
I need some time to research the encryption/decryption logic OR...
if CoDeSys really prompt for a PASSWORD (not for a KEY) - send me whole project, the library key must be stored somewhere in there...
This is my whole project files, please read "Readme.txt" file.
http://depositfiles.com/files/k4j0kvuq6
Thanks for help from Linkinx64,
Thanks all !
Thanks all !
Re: [?]: Is Possible to unpassword ABB CoDeSys User Library
I have totally knew the encrypt algorithm which is used to generate the " CoDeSys Internal Library File (*.lib)"
but...
only from encrypted *.lib file, I could find out only a little information and couldn't decrypt it.
still for help!!
but...
still for help!!
At the moment I can only say the follow information about heroctrol.lib:
1. The library has no password protection inside.
2. User key is greater or equal 5 characters.
I feel on pictures below referring to the same data block:
heroctrol.lib:
not encrypted library:
Check the difference in columns: when data block contains same data (00) after encryption it looks like series where low bits keeps same and high bits changing. E.g., for column #2: C9 F9 E9 99 89. For identical data block you may also see next row is very similar to previous. The data almost repeats each 16 bytes... so, cryptographic key length = 16 bytes.
If it is possible to define repeatability per each row and if there are simple byte operation is used (e.g. key-byte XOR file-byte) - the chance to decrypt file is quite big..
heroctrol.lib:
Thanks, Linkinx64!
You are right. It's a KEY, not password.
I have solved this problem and opened my user library files,
Thanks all, again!
Thanks all, again!
I need help on this CodeSys library. If you explain me how to do, it would be great.
https://rapidshare.com/files/355085887/ModbusTCP.lib
Re: [?+]: unPassword Library in ABB Compact Control Builder
I will explain: type 3SMODTCP when that library request for a password.tox92 wrote:I need help on this CodeSys library. If you explain me how to do, it would be great.
amit_sabby wrote:http://dl.dropbox.com/u/36769999/WINDER-1-0-0.rar
i would like to have your service again.
please i need password for few libraries in link given.
thanks for your last posting.
ACS600 and WINDER: matabunkay
WINDER_2: KREMIKOVTZI
Re: unPassword CodeSys library
Can you attach ModbusTCP lib again in order to try it?
BR
BR
Password is correct. 3SMODTCP
I know it works ! I just mean how did you do to find it ?
your lib file is very simple,tox92 wrote:I know it works ! I just mean how did you do to find it ?
only read password, no write password, no usergroup passwords (level 0-7)
especially no key!
search this forum with keywords "Bechoff keygen"
you can also get the correct password in 1 second!
Yes, search it in forum. To mention that 'Bechoff way' is possible do not helps in some cases.
BR
BR
I cannot find any "bechoff soft" in forum search.
Could you place here the link to the "bechoff soft" topic?
It should be Beckhoff KeyGen.
BR
BR
Thanks!
A good tool but not working in some cases when number of passwords in library > 1.
In v2.4 when fail to decrypt "need to pay for help"
Exactly.
In 2.3 and decrypt is not working too.
it always could crack the read/write password,
but for some lib file with two kinds of passwords at same time,
it will fail to crack group passwords.
if you have the problem, please upload the files and I can help
Hello everyone!
can anyone decode this codesys lib?
http://www.file-upload.net/download-738 ... i.Lib.html
Can you attach ModbusTCP lib again? !!!
Re: [solved] Is Possible to unpassword ABB CoDeSys User Libr
Hello Linkinx64,
Could you please help me unpassword in following zip?
Link_is_Dead :(/abc.zip
Thank you.
cnCraneBasicLib
cnCraneStandardLib
cnGrabControlLib
cnGsuAutoLib
cnGsuBasicLib
Thank you.
cnCraneBasicLib
cnCraneStandardLib
cnGrabControlLib
cnGsuAutoLib
cnGsuBasicLib
Hello
I have library coded with CodeSys.
File: http://s000.tinyupload.com/?file_id=516 ... 6776742830
Unfortunatelly there are two passwords set at the same time.
Can You guys help me?
Martin.
PS. If this will encourage You I will pay for help.
Martin.
Hy all.
I have library coded with CodeSys 2.2 with password, and I have a Beckhoff KEY V2.1, which can not be opened.
If you have a version V2.4 or greater, would you send me a link where I can download , please?
Lib: http://www.filedropper.com/showdownload.php/atmobaseqr
Regards .
PS: I have a version 2.4 but does not resolve. If anyone has any idea how to open the library , please write to me
Regards .
Anyone can share "Bechoff keygen"? Cos i cant find it.
up this post because me too I can't find the tool.yeosh99 wrote:Anyone can share "Bechoff keygen"? Cos i cant find it.
Plz I have a project at plc abb ac500 with codesys when I try to open it it ask for password and there are levels for it from 0 to 7 can I know password
