Page 1 of 1
?:How to update ELAU motor controller MC-4 firmware <= V15.x
Posted: Sun Oct 23, 2011 5:25 am
by iop_p
Hi all,
I have a very urgent problem with ELAU MC-4 firmware update, I tried a lot of methods to solved it used my DIY sreial cable, but alaways failured
Now I write the step what I had done:
A.
MC-4 side------------------------------------------PC side
2-----------------------------------------------------3
3-----------------------------------------------------2
4-----------------------------------------------------5
Result: The "Firmware Assistant" can't detcted the moudle
B.
MC-4 side--------------------------------------------PC side
2-----------------------------------------------------2
3-----------------------------------------------------3
Result: The same as above
C.
MC-4 side-------------------------------------------PC side
5-----------------------------------------------------5
Result: The "Firmware Assistant" can detcted the moudle now, but it alaways let me try lower baudrate, I tried change the baudrate, but no use.
D.
4-----
Result: The same as above.
E.
6------
So, what should I do now, does anybody have an idea, pls share to me. Thanx (sos) (fback)
Re: ?:How to update ELAU motor controller MC-4 firmware <= V
Posted: Fri Nov 22, 2013 8:54 am
by SSSeif
hello!
did you find a solution? i have the same problem...
Posted: Tue Nov 26, 2013 12:52 pm
by apilife
Some ELAU guys seem to have symmetry difficulty with pinouts...
Here is my cable pinout diagram.
Be careful: always shut down power before connecting or disconnecting cable on X7... or this port may definitely burn out !
It is much a better way to upgrade MC4 firmware through the controller with Ethernet connection when possible !
Posted: Thu Dec 19, 2013 7:02 am
by serg77
Hey.
apilife
Thank you very much for the description of the cable to the MC-4.
And where can I download the latest firmware for the MC-4?
Posted: Thu Dec 19, 2013 12:11 pm
by apilife
You can look for firmware on http://www.elau.com/downloads.html
First you have to register, then look in PacDrive M downloads.
Posted: Thu Dec 19, 2013 3:12 pm
by serg77
I was there but there is no firmware. Once the program
PacDrive Diagnostics.
Posted: Thu Dec 19, 2013 3:42 pm
by apilife
After login, I see the firmware files (Downloads -> Download PacDrive M -> Software -> Firmware).
Here is the direct link : http://www.elau.com/fileadmin/user_uplo ... 05_MC4.zip
Posted: Mon Dec 23, 2013 8:59 am
by serg77
apilife (tyou)
Thank you very much!
Posted: Wed Jan 15, 2014 3:10 pm
by jackberg
Hi there,
Have you solved your problem? Because I have the same communication problem. Tried the pinout mentionned. Also, I can't find the Pacdrive Sercos firmware assistant software anywhere on the Elau website. Does anyone have it?
Posted: Thu Jan 16, 2014 9:44 am
by serg77
Hello everyone.
To jackberg
The problem was solved. I have an assistant for the firmware.
This service CD. There's a lot of interesting things.
http://yadi.sk/d/JoDyE5gsGAX89
The password-a personal message.
Posted: Wed Jan 22, 2014 5:13 pm
by Rudi_budi
Hi all,
I have got download from this link,
don't understand about password...please help?
anyone please
Posted: Thu Jan 23, 2014 10:36 am
by serg77
Hello everyone.
Password for archive ----- sercos1977
Use luck :D :D :D
Posted: Sat Jan 25, 2014 12:55 pm
by Rudi_budi
Hello serg777,
Thanks a lot (clap) 8) (clap)
Rudi_budi
Posted: Sun Jan 04, 2015 1:49 pm
by usefi5961
dear all:
i want connect to packdrie diagnostics software but by building cable (aboe schematic)i can not connect to drive please if anyone help me send fresh schematic for building this cable.
4----------------2
1----------------3
2,3----------------5
Posted: Sat Jan 09, 2016 10:27 pm
by japiejoo
hello everyone
I need Firmware version V00_12_52 for my MC-4
kan anybody help me, i can't found this file
Thanks ans regards
Hans
Posted: Thu Jan 14, 2016 7:25 am
by guerik
great Thanks.
Posted: Mon Jan 18, 2016 8:36 am
by goffka
Thank you so much for all the listed information.
Successfully update firmware on the MC4.
For some reason, there was an error on the drive and is not reset. All elements are intact. Firmware was 22.05, I again flashed the same drive and earned.
All thanks again!
Posted: Thu Jul 21, 2016 12:58 pm
by esvblog
Hi and helloo.
First i've read all info from this post.
And i do have trouble with connection.
I've made cable as is shown (i have doubt that i do not make mistake) there is no ifo from where i see connector to MLAU.
But i have found GND
But still no connection
i see on scope that computer sending some transmit. But no receive at all.
i have two MC-4 and on both the same situation.
i have use a diagnostics v3 tool (from schneider)
What i do wrong ?
do i have to connect pin 6 or 5 ?
or maybe pin PRO_sel i have to disconnect or connect to +5V
Best regards
Mark
Posted: Fri Jul 22, 2016 8:40 am
by esvblog
It is solved...
i have conflict with RS drivers from other programs.
i have made succesfully update firmware :D
Thanks a lot.
Posted: Thu Mar 23, 2017 9:54 am
by aleksei112
The problem with connecting to Elau mc 4 is up-to-date, did everything as it is written above - it was not possible to connect.
I will be grateful for help
Posted: Sat Jul 15, 2017 8:35 pm
by ramiers
apilife wrote:Hello,
Hi, could you tell me how to upgrade through the controller? tx
Re: ?:How to update ELAU motor controller MC-4 firmware <= V15.x
Posted: Sun Jun 09, 2019 9:44 am
by usefi5961
dear members:
sorry,i try to connect to mc4 by firmware assistant and pacdrive diagnostics by rs232 cable but i can not connect to drive,please help me how can i connect to it and what is rs232-sel and pro-sel pin of x7 connector?(my pacdrive mc4 is version 16.32)
Posted: Tue Aug 06, 2019 5:04 pm
by Hassanazhar92
All thanks again!
Bro I have done everything you said.
but still getting the Error "Couldn't set the required baudrate. Try it with a lower baud rate"
Can you please share how did you solve it.
Its urgent
Posted: Tue Aug 06, 2019 5:20 pm
by goffka
Updated it a week ago again. There was no connection either. I managed to connect under the following conditions:
1 program is open and waiting for connection.
2 rs232 cable is connected.
3 ONLY after that connect 24v power.
Connection Speed ​​115.
Try it. If it doesn’t work out - write to me
Posted: Thu May 07, 2020 7:25 pm
by celiodalmagro
Hi. New on this forum. Thanks in advance for any help.
Does anyone have or know how to get Firmware_MC-4_V00_12_02?
