[LINK]:EPAS_V00.24.0301 & Password Library in ELAU EPAS-4
Hello everybody,
As I learned the servo software ELAU EPAS-4, I found that is good a software, but I have a lot of question with this software because there are just a little document introduce it, So I write my question here, if somebody know pls share it to me, Thanx very much:
1. I need the ECAM-4, an additional software that can creat CAM profile (pp3)
2. Password library in EPAS4, for example: PacDriveLib_V001507.lib (because I want see the FB;FUN source code )
Re: [Request] Password Library in ELAU EPAS-4?
Password ELAUAG97828
Re: [?+]: Password Library in ELAU EPAS-4
Thank you, that's great of you, but this password only can open "PacDriveLib" <= V001643, if open "PacDriveLib_V002011.lib", the password is failure, and there are some other library have different password, such as "PD_Template_V002012.lib" "PD_TPD_V002012.lib" "PD_VIS_V002003.lib" etc.
So if you know it pls share them for me...
And I have an another question about servo moudle MC-4 firmware, my MC-4 moudle firmware version is V001131, if I use Ethernet cable update the firmware via the sercos bus, it alaways failured, after I checked the manual, the firmware replacement using RS-232 serial interface connect to X7 (Interface which is in the MC-4), so do you know how to DIY that firmware download cable (15154304-030 E-SS-057), or should buy it from ELAU?
Thank you...555
Thank you...555
In my version of EPAS-4 (V00.22.03 b09) some of libraries you specified are missing. If you have newer version of EPAS-4 - upload it and I'll give you list of passwords for the protected libraries of your version of EPAS.iop_p wrote:Thank you, that's great of you, but this password only can open "PacDriveLib" <= V001643, if open "PacDriveLib_V002011.lib", the password is failure, and there are some other library have different password, such as "PD_Template_V002012.lib" "PD_TPD_V002012.lib" "PD_VIS_V002003.lib" etc.
Try this pinout: http://www.orbitmotion.com/Literature/L ... hnical.pdf on page 44.iop_p wrote:And I have an another question about servo moudle MC-4 firmware, my MC-4 moudle firmware version is V001131, if I use Ethernet cable update the firmware via the sercos bus, it alaways failured, after I checked the manual, the firmware replacement using RS-232 serial interface connect to X7 (Interface which is in the MC-4), so do you know how to DIY that firmware download cable (15154304-030 E-SS-057), or should buy it from ELAU?
Re: [LINK]:EPAS_V00.24.0301 & Password Library in ELAU EPAS-
Hi, Linkinx64
Now I upload the new verison EPAS_V00.24.0301, I hope you can crack all library files password...
http://www.megaupload.com/?d=9382PLM5
The pdf link that you give me is PMC-2, but I want to know module MC-4, and I also have this file, I just don't know how to DIY that firmware download cable ( in page61: -X7:1; X7:5; X7:6 I am not sure these 3 pins must use or not? )
http://www.megaupload.com/?d=XI4PV6LA
And by the way do you have "ECAM-4 Motion Toolkit" ?
ELAU EPAS-4: Library Passwords
Table Lib & Pass
Library Name Password
Basic_V000700 PACDriveLib
Basic_V000701 PACDriveLib
Basic_V001100 PACDriveLib
CHECK_V001101 ELAU97828
CSpline_V000501 ELAU97828
CSpline_V000701 ELAU97828
CSpline_V001200 ELAU97828
EasyTCP_UDP_V001630 ELAU97828
hmi_pcs_v000600 PACDriveLib
HMI_Simatic_V000601 PACDriveLib
Lic_V001100 ELAU97828
ModBus_v000703 PACDriveLib
ModBus_v001001 PACDriveLib
ModBus_v001200 PACDriveLib
NetVarUdp_LIB_V001630 ELAU97828
PacDriveLib_V001204 ELAU97828
PacDriveLib_V001209 ELAU97828
PacDriveLib_V001210 ELAU97828
PacDriveLib_V001501 ELAU97828
PacDriveLib_V001505 ELAU97828
PacDriveLib_V001507 ELAUAG97828
PacDriveLib_V001641 ELAUAG97828
PacDriveLib_V001643 ELAUAG97828
PacDriveLib_V002002 ELAUAG190152
PacDriveLib_V002010 D7WQ9Q8EUED6
PacDriveLib_V002011 Diekuhranntebissiefiel
PacDriveTemplate_V001643 Q9L8NKZX789
PD_EtherNetIP_Adapter_V002001 7JRGSFLJFLJ
PD_RoboticModule_V002000 KJA6RBVJHDI
PD_Template_V002000 UV429NWSX
PD_Template_V002001 8UC4LFGRESD
PD_Template_V002003 8UC4LFGRESD
PD_Template_V002012 7U1AQBNVJK98
PD_TPC_V002000 UV429NWSX
PD_TPC_V002001 8UC4LFGRESD
PD_TPC_V002002 8UC4LFGRESD
PD_TPC_V002003 8UC4LFGRESD
PD_TPC_V002012 7U1AQBNVJK98
PD_TPD_V002000 UV429NWSX
PD_TPD_V002001 8UC4LFGRESD
PD_TPD_V002002 8UC4LFGRESD
PD_TPD_V002003 8UC4LFGRESD
PD_TPD_V002012 7U1AQBNVJK98
PD_VIS_V002002 JHGFDSA7865
PD_VIS_V002003 JHGFDSA7865
PLC_V000600 PACDriveLib
PLC_V000601 ELAU97828
PLC_V000700 PACDriveLib
PLC_V000701 PACDriveLib
PLC_V000702 ELAU97828
PLC_V001200 ELAU97828
SercDrv_V001640 ELAU97828
SysSock_V001630 ELAU97828
System_V002000 LYP2WL8G6DJJ
System_V002001 LYP2WL8G6DJJ
System_V002200 JFJ935ZG-3RD
System_V002420 FG8ÖFDKG54
Trace_V001630 ELAU97828
Trace_V001631 ELAU97828
Trace_V001632 GRP9TUQ3EOR
VarioCam_V000700 PACDriveLib
VarioCam_V001000 PACDriveLib
VarioCam_V001100 PACDriveLib
VarioCam_V001103 PACDriveLib
VarioCam_V001105 PACDriveLib
XML_V001630 ELAU97828
XML_V001632 15823JNBLCX
http://www.mediafire.com/file/5oov1vx6v ... _UNPAS.xls
https://rapidshare.com/files/2708970228/EPAS_UNPAS.xls
No, I don't haveiop_p wrote:And by the way do you have "ECAM-4 Motion Toolkit" ?
That's cool & thanx, how do you crack that so quick, could you tell me pls?
I tried to DIY the firmware download cable use PIN:2, PIN:3, PIN5, the sercos assistant can detected it, but it cannot update the firmware, my MC-4 firmware version is lower than V15.xx, does anybody have idea?
I have a project made in EPAS-4_V22 but I can not open it because I forgot the password for the usergroup. Can anybody help ?
We probably can help you to remind but.. WHERE is the project?Platoon wrote:have a project made in EPAS-4_V22 but I can not open it because I forgot the password for the usergroup. Can anybody help ?
Hello somebody
Could you Tell me about Activate key EPAS-4 v.24 Please.
I have project , but can not pen because protect with password . please help me
Re: [LINK]:EPAS_V00.24.0301 & Password Library in ELAU EPAS-4
plz anyone provide software for this drive
PACDRIVE ELAU SCHNEIDER MC4
MODEL NO : VDM01D10AQ00
