[?]: how to format an SD card fot M340 PLC ?
другие контроллеры
jjdy
Post by jjdy » Thu Oct 06, 2011 6:53 pm
Hello.
Anybody knows how to format an SD card fot M340 PLC
It´s has an especial hard format. Thanks.
Kuzyma
Re: [?]: how to format an SD card fot M340 PLC ?
Post by Kuzyma » Fri Oct 07, 2011 9:28 am
I'm afraid there's no way to format SD card to M340. You need to buy the specific one from Schneider.
tintin2005
Post by tintin2005 » Sun Oct 09, 2011 9:39 pm
hello guys.
Yes! it´s possible to format THE sd card in m340.
reading....studing is the essencial part..... (read) (read)
You need to read the m340 manual and watch carefully to the system words.
if you inted to format an "non schneider " sd card i am not sure about it. I´ve already had an experience with it.
i formated an original sd card in my laptop and then put it back into m340 and formatted it again with m340´s %sw93 and it got back to life. The app i had inside before formatting it in the laptop got back perfectly working......
by the way after formatting it in the laptop the 8 megas ooriginal sd card turns into a 512 megas in fat format.... interesting .....no????
so if you want to test it make sure you have a 512 megayte sd card.
lucy for you
regards
tintin2005
jjdy
Post by jjdy » Tue Oct 25, 2011 9:45 pm
OK, thank you for yours comments. I`ll keep trying.
