Help me please on Unity Pro because I need a Pause Timer, it is a kind of timer that will pause the elpse time.
Because this block is available in Concept but in Unity this block is not available anymore.
So help please is there any available options?
[?]: Unity Pro and Pause Timer...
Re: [?]: Unity Pro and Pause Timer...
You can use TON with EN input for this purpose:
Yeah, you are right, it should be a little bit complicated Here is the code of TON_P after conversion from Concept:
it works...
IF RE ( IN )
THEN Max_summe_time:= t#0s ; ET:= t#0s; Actuel_ton_time :=t#0s;
END_IF;
Trig_St (CLK:= NOT PAUSE);
TON_ST ( IN:= (IN AND NOT PAUSE AND ET <= PT),
PT:=PT);
IF Trig_st.FALL THEN;
ELSE
Actuel_ton_time:= TON_ST.ET;
END_IF;
IF ET < PT THEN
ET:= Max_summe_time + Actuel_ton_time;
Q:= FALSE;
ELSIF ET >= PT THEN
Q:= TRUE;
END_IF;
IF Trig_St.FALL THEN
Max_summe_time := ET;
ELSE;
END_IF;
IF IN =FALSE AND PAUSE =FALSE THEN
ET := t#0s;
Max_summe_time := t#0s;
Q:= FALSE;
END_IF;
