[?]: Cable and soft for connection VIPA PLC
другие контроллеры
simontew
Post by simontew » Thu Jun 25, 2009 9:07 am
Hi All,
I need to connect to VIPA PLC 224.
I have the download cable for S7-200.
Can I use the Microwin software with the S7-200 PPI cable to connect to VIPA PLC?
Please advice.
Post by CoMod » Thu Jun 25, 2009 9:56 am
Not.
You can use GREEN cable (RS232 COM port) see viewtopic.php?t=4104&highlight=green
and software WinPLC viewtopic.php?t=7501&highlight=vipa
or Step7 v5.4 + VIPA GSD files for programming
I know only Russian link
http://www.cta.ru/cms/f/382077.pdf
Russian wrote:Конфигурация модулей VIPA с помощью ПО STEP 7 Simatic Manager
Татьяна Кузьмина
стр.86
В данной статье даётся ряд рекомендаций по работе с ПЛК VIPA с помощью программного обеспечения STEP 7 Simatic Manager от Siemens.
Schtiel
Post by Schtiel » Thu Jun 25, 2009 9:58 am
You should use Step7 and green cable, also you should download GSD-files for your PLC. How to connect to Vipa from Step7 is described here.
simontew
Post by simontew » Thu Jun 25, 2009 1:03 pm
Hi All,
Is "Green Cable" just a RS232 cable without any converter IC??
Pls advice. Thanks :?:
Post by sania » Thu Jun 25, 2009 1:10 pm
yes,but do not connect with the cable any MPI connector!
simontew
Post by simontew » Fri Jun 26, 2009 8:36 am
:lol:
Hi All,
it works.
thanks all support.
TaaviM8
Re:
Post by TaaviM8 » Mon Jun 14, 2010 5:01 pm
sania wrote:yes,but do not connect with the cable any MPI connector!
It causes some trouble?
*currently seeking for glues of my trouble with green cable :(
TaaviM8
Re: Re:
Post by TaaviM8 » Mon Jun 21, 2010 5:11 am
basically i said bye-bye to MPI port by connecting MPI and "green cable" together.
